Good Vibes
- Joined
- Feb 27, 2023
- Messages
- 153
- Likes
- 157
Really appreciate your response! I think I’m leaning towards the LS50s and integrate the KC62 In the mix. I think the KEF LS series does an incredible job with imaging. I just want to make the feel more whole when listening to music and not so much at the front. I think the LS50s can achieve that.
Unless there’s more opinions that think otherwise!![]()
In near field listening, with my nose pressed up against the holographic imaging, I found them to be exceptional but the more I moved away from them, the less immersive the experience. As others have said, the further away you sit, the louder you will need them and they do have SPL limitations. I sat approx 6ft away from them and they were loud enough for me.
To complicate things further, the biggest determining factor of how you will experience sound is your room size, the speakers position and your listening position within the room. The same set of speakers can give you a different experience in a different room and a different listening position. Chances are that you are currently experiencing peaks and nulls along the frequency range caused by your room and another set of speakers will have similar issues.
What are the dimensions of your room, how close to the wall will the speakers be and how far will your listening position be from them?
If only this hobby was a simple as buying good equipment and setting it up. Good sound is really about placement. There are many lessons to learn and it’s easy for a lot of info to go over your head until you find out the hard way. You have a decent set of speakers and a sub already so take your time in choosing your next set.
