how did you come to that conclusion when you say that there's 100% distortion at even 96db
The distortion in the LS50Meta at high volume is originating from the woofer. How? Because it is a coax design. The tweeter is a circle embedded into another bigger circle, the woofer. As the woofer starts to "bounce" out of his socket it pushes/shovels the soundwaves that originate from the tweeter with its own soundwaves sort of away. It basically creates ripples as it pushes/hits the tweeter soundwaves each time the base knocks. This is what those diamonds-shaped engravings in the woofers baffle are for to counter. Those diamonds are supposed to keep the harmonics of the ripple those base knocks produce as clean as possible. While this may do something it is not sufficient. The solution is as simple as Amir already suggested in the review.
Do not let that woofer visibly bounce!
This practically means that you need to run the LS50 Meta with a high pass crossover if you want to
a)play them clean loudly and/or
b)unleash their full potential even at low vol. Kef has them layed out for 80Hz HP but some even drive them from 100-120hz which allows them to play even louder. 80Hz should be fine up to ~96db tho which is the maximum 96% of people listen music to.
Why
b)?
I always wondered why KEF has a crazy subwoofer-esque in room response of 26hz in the specs with the LS50 Metas. They do not seem to bother applying a low cut on their own. You need to apply a cut off at about 47Hz which is the lowest they should attempt to play. If you send them a full range signal they will even at low volume somehow distort due to their drivers being somehow "shattered" of the very low frequencies they cannot handle. My pair sounded much more open after a cut @50hz without loosing a hair of base. In fact the base got a lot more refined, layered and enjoyable. I thought they sounded great before I realized all of this, but the truth is that they were "boomy" the opposite of layered but the boomyness was quite pleasant because they do have some sincere hammer-knock. But now knowing what they can really do I must declare a sincere recommendation:
DO NOT EVER GIVE THE LS50 META A FULL RANGE SIGNAL !
-The least and minimal effort thing you should do is to use software EQ in the music player of your choice to cut all frequencies below 50Hz with a steep slope. You will thank me.
-The best you can do is to High Pass Filter them at 80Hz or even higher. Of course you will need a sub to supplement. This will allow them not only to unleash the full potential of their drivers but will also free them up to play very loud, maybe even close to a 100db@1m with low distortion.
Some final remarks:
Amirs review has shown a
perfect, I mean like 98,3% or something accurate
"in room response" for the following frequency window:
- ~150Hz - 650Hz (perfection! ~98%)
from there it is still very impressive
- ~650Hz - 1000Hz (very good ~88%)
with some not very profound and EQ-able problems from
- ~1000Hz - 7000Hz (still quite good overall but some dips ~75-85%)
and again ending in close to perfection
- ~7000Hz - 20000Hz (close to perfection ~95%)
Human vocals (male and female) are @95% of tracks within the first row,
therefore being perfectly represented by the LS50 Meta. Maybe except for those rare female singers who can break glasses with their voices. Just in case you would want to hear those they can reach up to 900Hz and would in their absolute highest pitch be slightly distorted by the Metas (how sad
Well, and this is it. How much more do you want? There are two things exciting about music. The vocals and the base. For the latter you will have to look for a sub, but for the former you will not find a speaker up to around 99db@1m that beats the fifties (high passed). Even with internal DSP it is very hard, actually close to impossible to beat them.
edit: Almost forgot. There is another thing. You can screw and fasten them onto a plate! What this means is that you can add "stiffness" to their enclosure depending on the heftyness of the stand you mount them on. They are already quite stiff and heavy but you can turn them into concrete corpus-vibrations-wise. Of course this will affect their performance positively even further.
