KEF LS50 Meta Review (Speaker)
Aesthetically this shits over the sierra tbh. It will probably be my next purchase.
point taken , but that's about the only place i see an advantage...it's not like i'd turn down a free pair,but if i'm spending *my * money , i'll take a sierra or ceramic mini all day long ...
It's a small and pretty entry level speaker. We should keep our expectations to this.
Not for nothing (and I say this as someone who isn't huge on Genelecs), but it's the same price and size range as an 8030C (or G3), which has similar looks, but the Genelec has substantially lower distortion at the same levels. I expect better because there is better.
it's hard to see much value for passive speakers at and above $1500, especially if they look like made of plastic. I paid the same price for a pair of 8330
Been using my LS50 Meta pair (with EQ) for over a year now with each sitting on top of a Rythmik 12 servo sub built as 24" stands for them. Mostly listening with a crossover around 150Hz based on their frequency response. After seeing Erin's review, I bumped the crossover point to 300Hz to see if I could hear an improvement in the distortion. I can. It's not night and day but the added clarity is nice. I also hear less wander in the images, which was already quite good. I'll keep it there for a while. Worth a try, if you're curious.
CJH
Written review is live.
Let's see some GIF comparisons:
Spin:
Response Linearity:
86db distortion:
96db distortion:
I don't agree. There's plenty of models that can outperform speakers at US$1500/pair, even at higher price points.
I can recommend 13 speakers above this price point, from my 'passive recommendation speaker' thread, link in signature.
At the US$1000/pair sale price of the LS50 Meta, here's my current recommendations:
Bookshelves < US$1,000/pair:
NamePSPSwSubLFX
Ascend Acoustics Sierra 1 V2 (Erin)6.48.442
Philharmonic Ceramic Mini (Erin)5.97.942
Revel M16 with sealed port [readme] (Amir)5.9????
Elac Debut Reference DBR-62 (Amir)(Erin)5.27.446
Kef Q350 (Amir)5.77.538
Revel M16 with open port (Amir)5.67.745
Kef Q150 (Erin)4.97.045
Polk Audio Signature Elite ES20 (Amir)4.86.739
Arendal Sound 1961 Bookshelf (Erin)4.47.368
Since Erin reported two Preference Score values:
PS of 6.0 for LS50 Meta when on-axis
PS of 6.1 for LS50 Meta when 15 degrees off-axis.
That will become #2 recommendation for that price point.
This speaker becomes an easy recommendation at this price point, especially if you need great vertical directivity, such as for a near-field, like a computer desk.
NamePSPSwSubLFX
But that's what I meant, you can get more for less, $1000 for LS50 Meta is rather local or at some big discount, here it's still at equivalent of $1500 so I judge it at this price
Gotcha.
Since the introduction of LS50 Meta on Sep 2020, it was US$1500/pair until Aug 2021, then the price went up to US$1600/pair and stayed until Nov 23, 2023 where it dropped to US$1000/pair.
At US$1600/pair, it's a harder sell, of course. Since there's plenty of better performing speakers at that price.
At US$1000/pair, I think this has some serious value, being only beaten by Ascend Acoustics Sierra 1 V2, in terms of PS.
Another element to consider with the PS score you reference: the top of the top is not that much higher up. And by then, we're talking Blade or Perlisten S series...
Best performing bookshelf speaker is
-March Audio Sointuva AWG, with PS of 7.3 (in production) (at US$2k/each)
Best performing tower speakers are currently tied for same place, with PS of 7.5
-Kef Reference 5 (discontinued)
-Infinity Prelude MTS (discontinued)
-Kef Blade 1 Meta (in production) (at US$17.5k/each)
Which is better than PS of 6.0 for LS50 Meta, of course.
I say that a single digit increase of preference score is worth considering when comparing speakers to purchase.
But let's just say we compare bookshelves only...
- Is Kef LS50 Meta at US$1000/pair a good value against other passive bookshelves? Sure, there's a case to be made. If that case is "You need vertical directivity or just compact size?" Then yes, it's #1 pick. Otherwise Ascend Acoustics Sierra 1 V2 slightly takes the lead in terms of preference score, loudness, etc.
- Is March Audio Sointuva AWG at US$4000/pair, 4x better than Kef LS50 Meta? Nope. But there is an improvement, if you have the money.
If you can afford better, by all means, get a better one.
But if you cannot (money, size... You name your constrains); and that's the great part, the cheaper alternatives are not massively worse.
Not so long ago the gap was a lot bigger and that shortening is great news.
I was intrigued by Erin's discussion of the soundstaging, describing the "oval" soundstaging effect vs a strict rectangle. So he was trying to describe the phenomenon of where the soundstage/imaging boundary of any recording seems very defined to it's edges, a sort of "hard stop" as it were, vs the sense that the boundaries are a bit more fuzzy and so it can feel like the soundstage keeps going beyond the boundaries of the speakers. He says he prefers that more open, fuzzier boundary vs the hard stop.
I know what he means. I tend to prefer it as well, as it tends to sound a bit more natural to me, and it also helps give more of the peering in to a broad soundstage effect rather than peering at an event through a picture frame.
Anyone else know what Erin is describing, and do you have a preference?
I'm no expert, but my guess is directivity and phase coherence between the drivers might account for this phenomenon.
CJH
NamePSPSwSubLFX
I don’t know if you noticed but the 15 degrees off-axis spin has an extra .2 points
I think it’s one of the best measuring passive speakers out there for its price.
With such small woofer it's totally nearfield.
For loud fullrange one will need some midbass augmentation, not just the ordinary subwoofer...
Any truth to this?
With something like MiniDSP you can set these up crossed with sub(s) at something like 100hz @ 48db/oct.
I assume this would allow the KEF's to be pushed significantly beyond the distortion limiting levels presented with full-range use.
Any truth to this?
Dependes on listening volume low to medium and thast it the kef as good it is is small
