There is no standard for IMD measurements on speakers. If you know otherwise please show.
During the design of our Silver 5L we measured IMD using frequency pairs of 50-70Hz and 500-700Hz. It was order of magnitude less than THD within the SPL limit of the speaker.
Well that's fine, but it doesn't prove anything about speakers in general, nor does it answer my question because you can measure the amount but you can't say how audible it is or is not.
In general I don't think THD/IMD are very useful. A number of studies(
Perception & Thresholds of Nonlinear Distortion using Complex Signals, Geddes' work, etc) have found that the numbers they produce have little correlation with perceptual preference. There are suggested alternative distortion measurements but nothing that has seen significant adoption as far as I know.
The state of distortion measurement is honestly very poor. It should be possible to produce graphs where the information corresponds, in a clear and understandable manner, with audibility thresholds so that one can see, in one step, where a speaker is exceeding those thresholds and how bad it would be. However we cannot do that. So the whole situation is a big mess as far as I can see.
