KEF LS 50 Meta: NAD C 326BEE a good match/stands suggestions
marco80
Hi there,
I'm about to replace my Kef IQ 9s with the new LS 50 Metas. I got a NAD C 326BEE (https://nadelectronics.com/product/c-326-stereo-integrated-amplifier/) and plan to place them in a 24 m2 room. Behind the amp, there's usually vinyl or digital from a Topping E30 coming in.
Any thoughts on if the NAD is a good match for the Metas? Also, I need to protect these from my son and am looking for some very sturdy floor stand for them (that maybe don't cost 450 EUR and look good).
Thanks!
Marco
Update: Just got some for testing and they work very well together so far!
It depends on how loud you like to listen and ho big your room is I guess... It's not super powerful but should be competent enough.
Stands: any cheap stand that you can fill with something will be very sturdy and even Labrador proof... No promise for kids though.
The Sanus steel foundation stands and Monoprice monolith are ones I see recommended frequently. As long as it is weighted down with some sand/cat litter etc. so that the hollow tubes don't ring, they should do fine.
Thanks for the suggestions. I'll probably go with a wall mount, for now. Should be fine with these kinds of speakers I've tested setting them pretty close to the wall with the stands. And rather have a not exactly perfect setup than these things hitting the kid...
