LumiAudioNut
- Joined
- Mar 19, 2025
- Messages
- 64
- Likes
- 91
As are as I can tell, there still isn't a thread devoted to the KEF Coda W wireless HiFi speakers (these have been on the KEF website for about 3 weeks now)
So here goes:
us.kef.com
Coda W
Drive units
Uni-Q Driver Array:
HF: 25 mm (1 in.) aluminium dome
LF/MF: 130 mm (5.25 in.) magnesium/aluminium alloy cone
Frequency range (-6dB) measured at 85dB/1m
38Hz - 20kHz
*Depends on EQ Settings
Frequency response (±3dB) measured at 85dB/1m
41Hz - 20kHz
Amplifier output power (per speaker)
LF: 70W HF: 30W
Amplifier class (per speaker)
LF: Class D HF: Class D
Max SPL measured at 1m
102 dB
Wireless streaming features
Bluetooth 5.4
aptX Adaptive™, aptX Lossless™
Source resolution
Optical up to 96kHz/24bit
USB Type C up to 192kHz/24bit
HDMI up to 1.411 Mbps PCM
*Depends on source resolution
Interspeaker connection
Wired: all sources resampled to 96kHz/24bit PCM
Dimensions (H x W x D per speaker)
285 x 168 x 268 mm (11.2 x 6.6 x 10.55 in.)
Weight (per set)
11.3kg
Power input
100 – 240VAC 50/60Hz
Power consumption
200W (operating power)
<0.5W (standby power)
Primary speaker
Inputs
HDMI
Optical
USB Type C
RCA (Without Phono stage)
RCA (With Phono stage)
USB Type C (interspeaker)
Bluetooth
Output
RCA Subwoofer output
USB Type C (5V DC)
Secondary speaker
Inputs
So here goes:
Coda W
Experience pristine, high-fidelity sound with the KEF Coda W wireless speaker. Featuring a 12th Gen Uni-Q driver and seamless connectivity.
SPECIFICATIONS
ModelCoda W
Drive units
Uni-Q Driver Array:
38Hz - 20kHz
41Hz - 20kHz
LF: 70W HF: 30W
102 dB
Bluetooth 5.4
Source resolution
Weight (per set)
11.3kg
Power input
Power consumption
Primary speaker
Inputs
HDMI
Optical
USB Type C
Bluetooth
Output
USB Type C (5V DC)
Secondary speaker
Inputs
