KEF Ci200RR-THX In-ceiling/In-Wall Speaker Review
Rate this speaker:
    Votes: 2 1.2%
    Votes: 29 16.9%
    Votes: 88 51.2%
    Votes: 53 30.8%
I got a great deal on four of these (actually the square variety - Ci200RS) — two as ATMOS heights and two as L/R in a secondary room — and I'm really impressed. The bass goes deep, and they're *loud* (I guess I should have expected that with 90dB of sensitivity). I think if you actually put the rated 190w into them, you'd seriously shake your ceiling!
All that, and they're only a little worse at imaging than my LS50 Metas. I'll do some measurements on the L/R pair in a few weeks and see how well they react to EQing.
Just got around to measuring these in my room and they're really flat down to ~55Hz. I think this is the flattest pre-eq measurement I've ever taken. I guess the ceiling mounted position helps to remove unwanted interactions with objects in the room.
The yellow line is an SVS SB1000 Pro sub which I got to fill in the sub-55Hz region (it already has some eq applied). The green/blue lines are the Ci200RS L/R units and they have no eq.
I suspect the huge spike at 9Hz (way lower than the sub!) is a resonance of the ceiling cavity itself.
That looks about right. I cross mine over at 60 Hz.
I've enjoyed reading all the posts here and appreciate Amir's always thoughtful and thorough testing. Also appreciate the info (from Ellebob and thebizz) about placement of non-directional in-ceiling speakers like the 200rr's and how important it is to get them to cover the listening area instead of just one seat.
As I've mentioned in other posts here in ASR, I have a large daylight basement that will be divided into two separated areas. Hopefully I can attach a floorplan diagram to this - if it works, the red area is the HT room. The room will hopefully have coffer beam type ceiling similar to the attached pics and although the other two pics are WAY overboard, it will have a very bohemian/opium den style with lots of carpets, tapestries, heavy curtains, and other reflection deadening treatments. The system will be most likely a 7.2.4 setup. The front wall will include the large flatscreen, a nice open rack below it for the main gear and most likely a couple of side racks/bookshelves for other gear etc. The room will have 1-2 dedicated viewing rows and then another lounge type area behind right and I would want the most critical sound to hit the dedicated rows with ok sound for the lounge area (probably used more for just listening to music). I have all the speakers I need for LCR and surrounds (mostly Paradigm Ref Series and NHT SuperOne 2.1 bookshelves for surrounds, but I don't have anything yet for the ceiling. Ceiling is 10' high to the drywall now. I may have to abandon the beams if they are too disruptive of the sound, but I've seen other HT rooms that did it.
I'd like to go with a 4 speaker setup (FR/FL/BR/BL) and have read so much about all the plusses and minuses of non-directional (like the 200rr) vs directional (Focal 300 ICW8 etc) but am still trying to decide. I think spending $4K plus for Atmos ceiling speakers like these 200rr's may be out of the budget what with all the other build I have to do and gear to buy, cabling, etc, etc. One thing about these higher end in-ceiling speakers that is a bit confusing to me is that they are just that - really good speakers with great bass, midrange, highs, etc. - but really, isn't the object here to have in-ceiling atmos speakers handle the transient, passing sounds of planes, bullets, etc going overhead? So do they really need to be as great as the LCR's or even close? What in-ceiling speaker would you suggest that would be a bit more budget friendly?? Any other thoughts??
  • M Basement Lounge Buildout Sketch Public.pdf
Go on eBay. They are around $700-$800 a piece brand new.
We are considering in-wall speakers for our home theater room/media room. 14' x 19' x 8' ceiling, movies/TV only, no music.
I am considering the Ci200RS-THX as a potential L/R speaker, coupled with a LS50 Meta as center (already own this). The center will not be in-wall but on a cabinet. The R2 Meta could be a future center upgrade.
Alternative L/R is the Ci3120QLM-THX in-wall, basically same price as 200RS. Our wall cavity will support a 5" deep speaker like the Ci200RS. We do have smaller REL subs and this will likely be a 3.1 set-up for the foreseeable future.
Thoughts? Thank you for reading --
Opium Den! Chasing the dragon are we?
