Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 8,340
- Likes
- 11,228
Is the KEF Blade One Meta basically the same but with more bass output?
Only fair to compare like for like:The 2 is a better speaker all around.Easily compare loudspeakers measurements
www.spinorama.org
This is a funny remark, considering how simple it is to get good directivity in the 2-10Khz region and how bad this speaker looks below that (consequence of the narrow design).DirectivityView attachment 467410
Impressive.
As always, KEF’s mastery of directivity control shines through.
It’s simply beautiful.
Great results but there's something important to add: these are passive, so you need to factor in the cost of the amp(s) of you don't already have something suitable (KEF recommend 50-400 W RMS/channel). What did you use for the measurements?View attachment 467404
KEF’s high-end flagship — the Blade Two Meta.
Due to its price, significant weight, and unusually shaped cabinet, I was unable to measure deviation between 2 samples and vertical directivity. I appreciate your understanding.
Impedance
View attachment 467405View attachment 467406
Frequency Response
Across the full audible range, the response is exceptionally flat.
The -6 dB low-end extension reaches down to about 33.6 Hz.
Although the low-frequency roll-off is fairly steep, the usable bandwidth is still more than sufficient.
Nearfield Measurements
Multiple components work in harmony to create something truly cohesive here.
The port shows no signs of pipe resonance, and the woofers exhibit an incredibly clean response.
This is engineering refinement at its finest.
Directivity
View attachment 467409View attachment 467410
Impressive.
Beamwidth
The beamwidth begins a smooth, graceful narrowing from around 800 Hz upward, showing excellent control across the range.
Polar Plot
Due to the speaker’s design and limitations of the time-window measurement method, a measurement artifact appears around 200 Hz on-axis (black line).
Once that’s excluded, the radiation pattern from 1 kHz up into the treble converges beautifully into near-perfect circles. It’s stunning.
THD
View attachment 467414View attachment 467415View attachment 467416
Even down to the 50 Hz region, total harmonic distortion remains around the 0.5% range.
Yes—50 Hz. That’s remarkable.
View attachment 467417View attachment 467418View attachment 467419
Even at 96 dB SPL@1m output, the performance in the sub-bass remains impressively clean.
Truly outstanding.
Multitone Test
This is what true scale and engineering prowess look like.
The speaker asserts its dominance with ease.
View attachment 467423View attachment 467424
The distortion was already so low to begin with that even at higher output levels, the increase in distortion is negligible.
Stellar performance.
Compression Test
Within the test bandwidth, the compression results are practically flat — almost error-level behavior.
Utterly powerful.
Final Thoughts
Blade Two Meta doesn’t compromise between stunning design and top-tier performance.
In any reasonably sized listening room, I believe it will deliver exceptional results — no matter where you place it.
Nice review! Indeed these are very well designed and engineered speakers. My only concern is the impedance. If I read it correctly, there are many areas where it dips below 4OHMs and even below 2OHMs. By looking at this, it seems this will be a considerable load on the amplifier.
In these days of Hypex and Ice, etc amplifiers modules,Great results but there's something important to add: these are passive, so you need to factor in the cost of the amp(s) of you don't already have something suitable (KEF recommend 50-400 W RMS/channel). What did you use for the measurements?
Also, these are available in a range of colours, which might make quite a difference with such an imposing design.
Yes, I appreciate that, but it's still something to consider, especially if you're upgrading from really old stuff.In these days of Hypexand Ice, etc amplifiers modules, n
ot a real issue: $ or Euros 1000 or 2000 later…
The value of the 2 is the better directivity control, starting lower, which is perceptually more relevant. Bass is more or less the same and would be subject to EQ and room effects anyway.Only fair to compare like for like:
View attachment 467647 View attachment 467648
I don't see it.
The One offers deeper bass response and for that you give up nothing of value (except money).
Yup!Am I the only one who doesn't like the appearance of them?
I think they are ugly too. I've seen them in person, which reinforced the impression. And KEF's Muons are also super ugly. I didn't get to hear them since it was a pure display model at a show, disconnected on a pedestal.Am I the only one who doesn't like the appearance of them?
Nah, I think I'll stick with the these-days flawed but great sounding 'Concerto' from the early to mid 70s - Proper looking speakers if placed on low stands...Yup!
Kef made the boxy Reference 5 especially for you.![]()
