I absolutely believe that the ELX could beat the Blade in a random comparison. Why do I think that? Because both speakers are very good tonality wise, but differ a lot in how it disperses the sound into a room. Let's take a look.
First is the direct sound, which is crucial for sound quality. Here, the difference is far from great. Listening window is largely within 1 dB of each other;
They are both very good here. The Blade has more power in the bass, which can be a good thing or a bad thing, depending on the room and placement, but otherwise they are very similar - if we take the scale into account. Nitpicking about the ups and downs of a minute difference can be interesting for some, but for me it's far more interesting how they compare in terms of reflections. Or rather, the specifics of the reflections.
I don't believe Total reflection power is all that relevant because I don't think it's possible to accurately weight the importance of each reflection across different rooms.
Why do I believe that? Mostly because of my own experiments with acoustic treatment and different speakers across different rooms with different results. But also because of circumstantial evidence throughout the thousands of discussions regarding preferred dispersion. Some like narrow, some like wide and some think they have found a preferred approximate. I myself have found the vertical reflections to be more important than I first thought. I have also found that I like wide horizontal dispersion.
We know what the research says, but most of the blind tests done by research seems to be done in a large room with considerable distance to most of the reflective surfaces. As far as I'm aware, no research has dived into what happens to preference if you take a "perfect" speaker with wide horizontal and narrow vertical vs a narrow horizontal and wide vertical "perfect" speaker and place it in a small, reflective room and then compare the results to a large room. Similarly, as far as I'm aware no research has dived into what happens if you try to tailor different frequency spectrum's to different dispersion goals while keeping the direct sound perfect.
Is it even possible to get close to an optimal dispersion pattern for reflective small rooms?
I don't know the answer to that, but I do believe the answer for why a certain speaker may beat another speaker in some rooms but not others lie in the smallest of details concerning dispersion. And here's the interesting part about ELX vs Blade 2. The ELX has about 4 dB less reflective sound power vertically - which is about the same effect of dispersion control as you would expect from a cardioide speaker. (Kii Three 4.6 dB)
Then there's the other benefit of RAAL tweeters, the wide horizontal dispersion. We've all heard people say they have this mysterious ethereal air and effortlessness about them. What's that all about? If I were to guess, I'd say the answer lies in the very wide dispersion and in the relative relationship between vertical and horizontal reflections.
The ELX side reflection power is about 3 dB higher from 2kHz and up.
If we take the estimated in-room response at face value, the speakers are within 1 dB of each other. But diving into the details we see that they differ greatly in how they achieve that in-room response. Is either of them closer to an ideal than the other? Maybe. For all rooms? Unlikely. For all users? Not a chance.
Bass response differences aside, these two speakers are more different in their path to excellency than they are more or less excellent. If matched in the bass department, I would still expect the Blade to be preferred in more rooms due to smoother response overall. But my confidence in any given random comparison in short-term listening would be about 50 %. Longer term listening/comparison I would change it to about 75 % confidence in favor of Blade because I do believe the Blades smoother LW response between 2-7 kHz and the directivity error of ELX (some reflections combine to create a peak) between 2-3 kHz may become noticeable over time.
