And now, vertical dispersion, where there is a much bigger difference between the ribbon and the dome.
Ribbon:
Dome:
Thanks- I still couldn't work out if the Ascends were in their best spot but I appreciate the link.
I forgot that this test included high-passing the Ascends and using a Rhythmik F12 for the low bits- makes sense now!
Not only that but to my eyes it seems like the titan tower measures slightly more neutral with the much smoother directivity. It's puzzling that Dave and so many others have claimed the ribbon version sounds better, it really makes you wonder if there is sighted bias at play. This would be an interesting experiment to have people compare them blind to see if their impressions change.
Ribbon tweeter will sound better in an a/b test the same way saltier or sweeter tastes better in a single a/b.
But long term, the extra reverb isn't preferred.
No sighted bias, we have had hundreds of direct comparisons between our ELX Ribbon Towers and ELX Titan Towers (dome tweeter). Results are remarkably consistent, 8 out of 10 prefer the 70-20xram ribbons. And this consistency is fully evident in comparing our ELX Titan against the Blade 2 and ELX Ribbon against the blade 2. It can't be denied.
There is still more to learn about what we hear than is being captured by NFS measurements, we are always getting closer though. I have even done comparative listening outside, which is nearly all direct sound so directivity isn't nearly as much as a factor - it became even easier to hear differences between the 70-20xram and even some of the best dome tweeters available. There is a character to the 70-20xram, an overall smoothness with more precise attack and decay that is very evident once you start to notice it. Not everyone hears this though, and - like the results of these various comparisons, it completely depends on the music being listened to.
I understand that but you didn't clarify if these direct comparisons were blind, if they weren't I'm not sure how it can be claimed no bias is present. I mean the fact that it's a ribbon, an upgrade and more expensive are all very feasible reasons why people would be biased into thinking the ribbon is better than the dome.
Are you saying tweeters dont have stored energy or they have? Im pretty sure you are more knowledgeable than many of us here.‘Stored’ energy in a tweeter?
So this is kind of what I basing my opinion on that if the ribbon ELX truly does beat the titan dome in a properly controlled blind listening test, it would be interesting to figure out why because I'm not seeing anything in the measurements that would point to that.
I'm fairly certain Dave at Ascend has much more knowledge than any of us here as well,but for some reason his knowledge gets questioned because he sells the actual product he designs and develops.Are you saying tweeters dont have stored energy or they have? Im pretty sure you are more knowledgeable than many of us here.
Well but Purited is asking about tweeter in general not a particular product from ascend. So are you saying only tweeter sold from ascend have stored energy and the rest of the tweeters used from other manufacturers dont have stored energy or perhaps it does?I'm fairly certain Dave at Ascend has much more knowledge than any of us here as well,but for some reason his knowledge gets questioned because he sells the actual product he designs and develops.
So tweeters do have stored energy. Different types of tweeters are going to have different level of stored energy. Thank youThe answer is rather complicated, but i'll summarize. All mass-spring systems have stored energy, but tweeters typically dissipate the energy much faster than woofers.
The decay of stored energy depends on the system's Q (damping), where lower Q = faster decay. Total Q (Qts) depends on the Thiele-Small parameters Qms (mechanical damping), Qes (electromagnetic damping).
Qms is affected by the compliance of the suspension and the mass of the cone. Tweeters have to move faster than woofers and have a lower excursion range, which means low mass diaphragms and stiffer suspensions, so they ring more. But they have a much lower Qes since the voice coil gap is much smaller than woofers, which means the BL (force factor) is much higher. Overall the Qts is lower, so tweeters ring less.
But ... for the sake of argument, suppose you take a tweeter and woofer with the same Qts, and let's say both of them ring for 5 cycles. For the tweeter, 5 cycles of 10kHz = 0.1ms. For the woofer, 5 cycles of 100Hz = 10ms. You can see that even though both of them have the exact same amount of ringing, the woofer rings for much longer.
I believe all this is correct, but it has been a long time since I read Vance Dickason's book. Will gratefully accept corrections if I am wrong.
Haven't seen this much unsubstantiated garbage in a ASR thread for awhile. The thing is even if you shut this thread down the self promoting Ascend clones keep opening a new thread with the same crazy comparisons. Wouldn't this be better kept in the desperate dealer section or not posted at all?
