quattro98
The color scales aren’t the same number of steps, but the Blade 2 Meta doesn’t have radically wider horizontal directivity than a standard forward facing speaker like the R11 Meta. I don’t know if they’re that much more sensitive to room placement just because we can see the woofers on the side instead of the front.
You can click through the links to see the difference in vertical directivity which is where the real difference lies (and thus doesn’t affect placement relative to side walls). For the forward firing speakers, the Reference 3 Meta and R7 Meta will have a smaller spacing between the woofers than the arrangement on Reference 5 Meta and R11 Meta, corresponding more even vertical dispersion.
The Blade is elegant in reducing diffraction in the upper frequencies (fewer squiggles on the graphs) relative to the box speakers and providing greater woofer area in a small vertical distance for the driver spacing.
www.audiosciencereview.com
KEF R11 Meta Tower Speaker Review
This is a review, listening tests, EQ and detailed measurements of the KEF R11 Meta floorstanding speaker. It was sent to me by the company and costs US $3250 each. The R11 Meta is gorgeous looking with high gloss finish and cabinet that has been shrunk as much as possible to basically hug the...
