Keep KH 750 sub or switch speakers
Just wanted to report that after trying out the setup for the last weeks, the calibration works really well with sub centered in front of me. I didn't change the settings Neumann calbration set and am now really satisfied with the result.
Also understood that I would need some serious bass absorption in the back if I wanted to fix the room mode at around 28hz.
Just add a tad of manual equalization to get rid of that bump.
If you say the bass is absent that " sounds"[ha see what I did there?] like a Phase issue. That is more than likely room related. See if you can beg, borrow or"aquire" twin subs to try & see if that loads your listening space a little better. If so you could easily find something half decent like that S/H for the price you could flog off the KH750's for. Also a bit of low end room boost isn't a bad thing. Eh, Just a subjective opinion. Me thinks all this flat response dreck LOOKS good on a PC screen. But who gives a toss if it don't SOUND good.
human hearing has low bass sensitivity at low volumes.
this is not correct, its the other way around.
for example, to match a 1KHz tone at 80dBSPL a 20HZ tone needs to be played at 113dBSPL which is a 33dbSPL perception difference, whereas at 1KHz tone at 100dBSPL would require 20hz @ 120dBSPL to match, as volume increase frequency response flattens is the best way to think of it
Your problem is targeting a flat response. This does not produce a pleasing or accurate sound
i disagree
targeting a flat response is correct as artists should be producing on a flat response. They can still mix the track how they would like so that others listening on a system with flat response can also enjoy it, mixing flat generally translates well to other systems, mixing with the sub at increased levels would give a false sense of how it will sound on systems that aren't flat or lack sub.
i disagree
Correct ----- and many naive producers do not understand this. Well stated.
