Kanto YU6 desktop use, Review and measurements.
HD65
5 month follow up.
Good.
sound is decent allow bass is a little boomy, dropping bass EQ down helps a little and hurts a little.
Once I went to smaller stands tilted up they sound 100% better
zero hum/hiss
Bad.
Bluetooth is always on and searching
Sound is a little boomy, EQ helps a little/hurts a little
Slow to wake up from sleep
THEY PICK UP A LOT of radio interference.
WORST is they don't start on last input, I have to use remote and hit "RCA" or push the volume knob in like 5 or 6 times.
All in all not a bad purchase, I wouldn't recommend but I wouldn't tell you not to either.
How is the Phone pre amp on them? or do you even use it?
D
Deleted member 51252
Guest
ALSO the built in dac via optical is mushy.
How bad is the dac via optical? I've been thinking about getting these for my TV, but I'd probably look at another option if the optical implementation is poor.
