Kali LP-UNF vs LP-6 when paired with sub
underneath42
Hey Team,
Long time reader, first time poster ;-) I'm upgrading my desktop setup - I'm WFH so it gets heavy use. The Kali LP-UNF seems to get rave reviews for it's size and price, so that was what I was thinking of going with, but I don't need the USB input or bluetooth. My engineer brain tells me
  1. With speakers, bigger is almost always better
  2. With the LP-UNF I'm paying for features I don't need
With the LP-6 there are bigger woofers and no bluetooth/USB, so it seems like more of the money should be going into what I want :-D And still within budget. That said, maybe the extra money is not worth it when paired with a subwoofer anyway?
For context, the rest of the signal chain will be Macbook to MiniDSP DDRC24 via USB, then RCA cables to speakers + a B&W AS608 subwoofer.
Caught in analysis paralysis... Any opinions? :-D Basically, given that the lows will be handled by a sub anyway, would there be any benefit to the larger woofer in the LP-6?
Hi @underneath42! Welcome to ASR.
Erin from Erin's Audio Corner has actually measured both the LP-6v2 and LP-UNF on his Klippel Nearfield Scanner, which gives you the best opportunity for an objective, apples to apples comparison:
I don't see any noteworthy advantage in frequency response or directivity, but harmonic distortion and dynamic range are expectedly better on the LP-6, even considering that they'll be high-passed.
And although Erin had not yet started measuring multitone distortion when he reviewed the LP-6, I'm fairly certain it would do better there as well.
Thanks heaps for the response! To be frank, while I did read the reviews before posting, I do struggle to understand all the graphs and what I’m looking for to compare, so the analysis you gave is much appreciated and I can see what you’re saying ;)
Since I’m hoping this will be my “end game” for my desk, seems like the LP-6 might be they way to go.
I'll be using an Energy brand powered sub with my Kali LP-UNF's - the M4 Mac Mini has an aggregated speaker output capability through the Midi settings. Pretty cool...
