dam, and i thought of upgrading to these from my cheap ass monitors for music production.Quick update about these speakers after owning them for some months now - I hate them (lol). Ok, maybe hate is a strong word. Probably my final update, most rehashing what I said before however.
The best thing about these speakers are the orientation options. I really like being able to see the difference between tweeter on top, tweeter on bottom, tweeter inside, and tweeter outside configurations. You can easily hear the differences and it shows up on measurements too. It gives you different "flavors" to play with that exist somewhere between personal preference and subtle difference. It's nice to know you can pick the variant you resonate with or what suits your content, without feeling like you're drastically deviating from the source material. Four orientations are better than one manufacturer dead set configuration that you need to accept.
- Without a subwoofer, it's a hard pass. Especially now that they are $1000 MSRP. I would personally not recommend them. With a sub, not for me. Without a sub, actual hate. ALL OF MY OBSERVATIONS ARE WITH A SUB ATTACHED AND SONARWORKS REFERENCE 4.
- The tweeter also continues to be as laid back and as unfatiguing as possible. It sounds more crisp if I stand up above them (for sure in off axis territory).
- There is a neutralness to these speakers that enters actively boring territory and ruins enjoyment. I get more enjoyment out of my heavily EQ'd phone speakers than this these, and those have no bass and inherently harsh tweeter.
- Subjectively describing the sound, IN-5 sounds undistorted and not harsh - not bad things, but it's too much. Lean/missing something without the subwoofer (blatantly less open). There is no excitement. Not a feeling of height or magnifying glasses. These are studio monitors, but they are not euphonic. So they also don't translate to any other low quality or cheap equipment either, like if you bounce around with different devices. Just the tuning and smoothness is too far off. I'm ok with crap hardware if it's tuned nicely enough. These are the opposite to me even after calibration.
- I will be hopefully replacing them with Adam Audio A8H and hoping it's not super sibilant. Black friday please come through for me! Also bonus points for 2ft driver blending distance (most speakers are 3ft)
Right now I am using tweeter inside, although I am probably going to switch it to tweeter outside. Tweeter inside gives sound of less width, increase in overall "softness", but an increase in coherentness and mental easyness to process and listen to analytically.
interesting review. Joe n tell and Erin preffer kali lp6 v2 over these, (probably because of the flatness across all freq range?.)
do you think lp6 v2 would sound better? Hve you heard em?
I guess i will look into buying adam t5/7v or lp6v2 ah
