songOVERsound
- Joined
- Mar 11, 2023
- Messages
- 204
- Likes
- 120
My in8’s measure flatter (in my room) than speakers that cost much much much much more
For sure. My room is heavily treated with all kinds of treatment including PSI AVAA’s. Room is flawed due to sizeMy experience over the years with various speakers is there's little correlation between price and sound quality in a typical untreated room with suboptimal placement and low SPL. In this scenario, having wide dispersion is way more important than FR flatness IMHO. I think that's the magic for good speech legibility at ~40dB outside the nearfield.
WowLooks like the SM5 active was released today. $1700 (each) with 8 bands of PEQ on board. Would love to see measurements of these, the design looks pretty promising and the specs ain't bad.
Kali Audio — Kali Audio SM Series Studio Monitors
www.kaliaudio.com
Slightly less bass extension but maybe slightly more SPL. Coaxial could make the Kali more versatile. Can use your own room calibration mic instead of getting the MA1. I think that and the actual measurements will decide it, but I agree it's close competition just based on the spec sheets.Wow
Same price as KH150
Powered, not active. Looks like they just bolted on a single channel plate amp/dsp with the passive crossover, vs doing a proper multi-amp setup.Looks like the SM5 active was released today. $1700 (each) with 8 bands of PEQ on board. Would love to see measurements of these, the design looks pretty promising and the specs ain't bad.
www.kaliaudio.com
Hmm, good catch. But they also have DSP on board, so I guess they are supplementing the crossover with that.Powered, not active. Looks like they just bolted a single channel plate amp with the passive crossover, on vs doing a proper multi-amp setup.
I do. Passive crossovers and a single channel of amplification is fine if the amp is separate, but for $1700 a pop it's a little bit absurd to use a single channel plate amp, especially considering their cheaper speakers are multiamped.I don’t see that as a problem. JBL 705i/708i are no better biamped than single-amped. The lack of grilles is a killer for home use though, IMO.
These are clearly intended for full-time recording pros -- or seriously dedicated amateurs -- rather than for folks' home listening spaces, where visual aesthetics are often a major consideration.Call me superficial, but they just look... cheap. Which was fine, when they where cheap, but this is now in the 'not cheap' price range. I'm sure if they sounded amazing I could get over it but still.
