Hello all
Here a brand new LP-UNF owner. Windows 11 25H2 Dutch, USB-C connected, on speakerstand close to wall.
I used to have a pair of iLoud Micro Monitors but got a bigger desk, so thought to up also in speaker format
For me it's purely as desktop speaker. So listening to HQ music, movies, some gaming, etc.
Got 2 questions and maybe you have some feedback on it?
- The LP-UNF sound is great and for sure an upgrade compared to the iLouds ... but only on high(er) volumes? I know this of course is a personal experience but on low(er) volumes the LP-UNF sounds "boring", there is no punch. The iLouds though are way more present on low(er) volumes, especially with bass.
The dipswitches on the back do not change that experience.
I tried to alter the sound somewhat with the FxSound software and that helps a small bit but still ...
An option to replace the LP-UNF are the Adam Audio D3V's. I presume those are a bit more present at lower volumes. But I don't know if those are an upgrade compared to the normal iLouds?
I also could go for the iLoud Micro Monitor Pro but that's way more expensive and I also have to get an audio interface for those.
Opinions?
- The volume adjustment with the Windows Volume Control is a bit weird? When I use that (either onscreen or with the volume keys on my keyboard), the volume change steps do not change equally all the time. For example, when going from 10 to 12, there is a small change. 12 to 14, there is no change. But then going from 14 to 16, there suddenly is a rather big jump in volume?
The volume on the speaker itself doesn't matter: I set that to Step 27 (0 dB) and tried others but the same problem. And using each time the volume on the speaker is just not practical (that touch volume is the only negative about the speakers).
This is not so with the iLouds: each volume change with Windows volume control is noticeable.
Thanks in advance for any info and/or opinion.
