Kali Audio LP-UNF
These things don’t go very loud anyway, I would not worry about power very much ;)
If size is not an issue definitely go with the MM-6. We have had both here where I work and I have a pair of the LP-UNF on my desk. The LP-UNF is very good for its size but for $120/$100 more the MM-6/LP-6 is a good step up. No Bluetooth in the MM-6 and the MM-6 uses its remote for volume instead of the front panel.
Thank you!
Given limitations dictated by space on desk, do you think lp-unf can be any good for mixing some classical music takes? Similarly priced offerings like krk goaux 4 seem to be contenders. Or do you think that higher priced Genelecs 8010 are a different league?
The 8010 is way smaller and cannot play nearly as deep as the LP-UNF.
You can use the website below to search for the right monitors, filter by price, type, brand, etc and sort by neutrality ("Score") or bass extension:
Hello, I'm still searching for the right setup at my desktop. I switched from Teufel Concept E Magnum to Klipsch R-41m which were horible. Then I got the Polk ES15 which were just "ok" and now I've got the Heco Aurora 300 which are good, but not perfect for nearfield listening. Would you recommend me to sell my Heco Aurora 300 (similar to Elac DBR62) and get the Kali LP-UNF or rather LP-6 v2?
Is the sound on these smooth ? I am new to speakers . I have been eyeing this speaker for quite some time . I usually prefer a neutral warm sound signature . Are these a good choice for that ?
I have a pair of these Kali LP-UNFs for several months now. Daily listening maybe an hour or so. Here's my very non-expert subjective opinions.
  1. At USD299, these are the best value speakers I have owned. And it comes with it's own amplification plus dipswitches for room correction.
  2. For near field listening and paired with a decent subwoofer and any decent streamer/preamp (I have used MXN10 and Wiim so far), the sound is very nice. I get great details and imaging. Soundstaging as a concept is still elusive to my ears/head. I would best describe the sound as neutral, accurate and nice tonality. I am considering if a pair of 3-5" woofer sized Genelecs or Neumann would give me a big upgrade. I think they would but won't know until I get them.
  3. If you want warm sound you can always play with EQ or PEQ at streamer/pre-amp level. Don't get so-called warm speakers is what I recommend. Get neutral speakers and use EQ to customize. I reckon how you place your speakers in relation to your ears and listening position will also make a lot of difference.
I'm considering to buy them and an Fosi Audio BT30D Pro. Would it be a good combination? I would like to use my current subwoofer from a Teufel Concept E Magnum with them.
You only need a preamp for these speakers. You’re better off buying something like the Wiim Pro Plus or Ultra or something similar to connect with it.
I'd be using them on my desktop only - connected to my computer. In terms of EQ, I'd be using PEACE. I'm currently using the subwoofer of the Teufel system as amp for my Heco Aurora 300s and a Fosi Audio P2 for my headphones, therefore I thought the Fosi Audio BT30D Pro would be a good option. Why do you think I'd be better off with a Wiim Pro Plus?
Sorry I don’t get why you’d want to use a power or integrated amp with a powered speaker like the LP UNFs. Thats why I think you’d be better off for about the same money to use something like the WiiM Pro Plus. Cos you get WiFi streaming capability on top of that. But of course that’s moot if you already have your laptop as your streamer or source. Then think a good DAC preamp like Topping D50III will be good or even an upgrade to Wiim Ultra for the dedicated sub out and DSP.
I'm open to any advices - I haven't decided what to buy yet, so I'm grateful for your comment. I want to sell my Heco Auora 300s and buy the Kali Audio LP-UNF because I think they might sound better because of my room setup (small room, speakers directly placed against the wall, small distance to the speakers). As they only have a 4,5"-woofer, I think I would miss deep bass - therefore I want to keep using my current subwoofer. I wish the Kalis had a sub-out - as they don't I thought about the Fosi Audio...
