That is basically what shows on the dB/kHz grid of the magazine's measurements. To be fair, at maximum acceptable distortion levels that is 105 dB SPL around 40 Hz for the 8260A (instead of @Absolute's good guess of ~50 Hz).Thankfully these 'little' Genelecs play noticeably higher than 105dB peak, and if you have the data showing what you're insinuating with your last line I'd love to see it. [...]
Max. 3% THD is considered for the blue curve and max. 10% THD for the red curve [8260A; reversed colors on the M2 grid], until the amplifier (RMS) limiters activate [on the M2, that is reached at 400 W for the woofer and 50 W for the tweeter; see editorial notes to the linked measurements - no specific information is given for the 8260A]. The 10% THD measurement was conducted until 250 Hz for the 8260A and until 300 Hz for the M2; all measurements taken at 1 meter [= 3.28 feet] distance and with a 185 ms Sinus sweep (information found on the 8260A review). Considering psychoacoustics, I would not want more than 10% THD in the bass region vs. 3% from the 'Low mid' upwards, as this clearly becomes audible (and much more damaging the listening experience, than some of the previously mentioned electronic hiss). Regarding "hiss", they measured a 26.8 dB(A) noise floor at 10 cm [~4 inches] distance for the 8260A vs. 30 dB(A) for the M2 [with 'Crown I-Tech 4x3500HD' amplifier at maximum input sensitivity]. However, I am not sure how much of a realistic idea this gives.
As of the chart you posted, the threshold of our hearing lies roughly at 75 dB for 20 Hz; equivalent to 0 dB at ~2 kHz, where our hearing is most sensitive. // At 100 dB SPL in 1-meter distance [theoretical equivalent of 92.25 dB SPL at 'your' 8 feet = 2.44 meters], the 8260A already shows 10% THD on the grid's low end. Those are quite good results for a loudspeaker of this size! But not comparable to the clean bass and headroom an M2 delivers.
[EDIT]
Unfortunately, they cut off the M2 grid at 40 Hz, it seems. My previously linked in-room measurements of the M2 show worst ~5% THD at ~15 Hz; @ 90 dB SPL and ~10 feet listening distance. // Out of interest, would you be able to provide similar measurements of your 8260A, without application of GLM or similar? Easiest way would be using a UMIK-1 with REW.
