Unfortunately just that, interested enough to spend on equipment but not interested enough to learn how things actually work.
What does this mean to you? Is there just a SINAD limit, or a more complex set of metrics that an amplifier needs to clear, in order to be considered transparent?transparently measured amps
We have more than one thread on this very topic. No, for the 11 millionth time, it is not just SINAD. Pardon my sensitivity to the idea SINAD tells all.What does this mean to you? Is there just a SINAD limit, or a more complex set of metrics that an amplifier needs to clear, in order to be considered transparent?
I had seen those posts (your first "some more" is the same as the first one btw), I just wasn't sure what it means to you.We have more than one thread on this very topic. No, for the 11 millionth time, it is not just SINAD. Pardon my sensitivity to the idea SINAD tells all.
Here is one.
When is a DAC or Amp audibly transparent?
At what SINAD and other metrics can we consider a DAC or Amp audibly transparent? I know we want a well engineered device, but at what threshold can you no longer hear a difference (even for very trained ears)?www.audiosciencereview.com
And some more.
Audibility thresholds of amp and DAC measurements
Introduction A recurring theme on ASR is whether or not the various measured qualities of the devices are audible. In this post, I'll present some clear and visual thresholds for when those imperfections can be considered a potentially audible concern. I will not explain the basics of amp/DAC...www.audiosciencereview.com
What matters about SINAD measurements
First may I commend this site and its founder\admin for a fine service to several audio communities, ranging from newbies to audiophiles to professionals. I myself am in the latter category – a professional audio engineer since 1958 (my first paying gig after graduating RCA Institutes, and...www.audiosciencereview.com
There may be a handful that meet strict or come very close. Plenty pass lenient. Not all, but plenty. You need to add some provisions for covering 20hz to 20 khz and all the way up to rated power.I had seen those posts (your first "some more" is the same as the first one btw), I just wasn't sure what it means to you.
So we have:
Lenient
Dynamic range, linearity: 96 dB
THD, IMD: -66 dBFS / 0.05%
Noise: -85 dBFS / 0.005%
SINAD: 85 dB
Crosstalk: -60 dBFS
Frequency response: ±0.5 dB/octave
Channel balance: 1 dB
Output impedance: 2 ohms
Strict
Dynamic range, linearity, SINAD: 120 dB
THD, IMD, noise, crosstalk, jitter: -120 dBFS / 0.0001%
Frequency response, channel balance: ±0.1 dB
Output impedance: 0.16 ohms
"Strict" I think it's mostly out of the question.
I wonder how many >100W (8Ω) amplifiers are there, that pass "lenient"? I was looking at some Stereophile measurements for powerful amps and none seem to pass the "lenient" criteria.
If the criteria is very narrow, you can absolutely be correct but this is a "technically correct" kind of thing, with no much applicability.
Otherwise, the normal stuff most people buy, especially for big speakers, doesn't seem to be "transparent". So you're correct, but so is everyone else...
This is just a SINAD list, it doesn't cover the criteria. Or do you have a different position, that a specific SINAD threshold is all an amp needs to basically be in kern(amps)?Amplifier SINAD list ASR + 3rd parties
docs.google.com
Not the ones I've seen so far and certainly nothing I personally own, but I will keep looking.There may be a handful that meet strict or come very close. Plenty pass lenient. Not all, but plenty. You need to add some provisions for covering 20hz to 20 khz and all the way up to rated power.
You can click on the "source" link for each amplifier for the rest of the measurements from the original reviews, most of the sources using AP analysers will have a variety of measurements and you will see that all the top measuring stuff usually satisfies most if not all the "lenient" criteria throughout most of its operational range.This is just a SINAD list, it doesn't cover the criteria. Or do you have a different position, that a specific SINAD threshold is all an amp needs to basically be in kern(amps)?
My impression is that it's a very weak claim. This is a by-product of the complex and restrictive criteria needed for it to be correct.
Wait, what?You can click on the "source" link for each amplifier for the rest of the measurements from the original reviews, most of the sources using AP analysers will have a variety of measurements and you will see that all the top measuring stuff usually satisfies most if not all the "lenient" criteria throughout most of its operational range.
Perhaps it was rhetorical one, but I was simply responding to your question: "I wonder how many >100W (8Ω) amplifiers are there, that pass 'lenient'?".Wait, what?
For "transparency", I think they should satisfy the "strict" criteria. The "lenient" stuff is a "maybe, depending on the listener" thing, if you look at the fine print.
Now you're telling me that not all "maybe"s are required, and we just go with "most", or "some"?
You can slice and dice the requirements, but this is always going to be a gray area. There is no dead clean and clear set of criteria unless they are all far beyond reproach. There are a small number of amps that can do that. You have THD all below -120 db as good enough, but possibly -80 db is going to be enough for 98% of people under conditions of music listening or maybe 99%. A wide somewhat gray area.Wait, what?
That's fine, I personally have no issue with someone postulating that amps passing the "strict" criteria are indistinguishable by any human observer. It sounds eminently reasonable. But I don't think it applies to much, if anything.You can slice and dice the requirements, but this is always going to be a gray area. There is no dead clean and clear set of criteria unless they are all far beyond reproach. There are a small number of amps that can do that. You have THD all below -120 db as good enough, but possibly -80 db is going to be enough for 98% of people under conditions of music listening or maybe 99%. A wide somewhat gray area.
Those are good, yes.Without looking, I think the Purifi amps meet these criteria in the lenient case, Benchmark, Mola Mola and some of the Hypex units. What are you seeing they don't meet?
That's because there is a physical thermal noise brickwall which is limiting SINAD.As for amplifiers specifically with >120 dB SINAD, there are virtually none measured.
This is why I posted thd not thd+n.That's because there is a physical thermal noise brickwall which is limiting SINAD.
It depends on:
Typical amps have 26dB gain (20x) and are measured at 5W here which is 4.5Vrms for a nominal 4Ohm load. Source impedance often in the 50Ohms range. Measurement bandwidth is 20Hz to 20kHz.
- amplifier gain
- test level (output voltage)
- source impedance and residual noise
- measurement bandwidth
Assuming a noiseless source and a noise- and distortionless amplifier this gives a 124dB brickwall:
50hms source resistance (at room temperature) with 20x of gain creates 2.6uVrms of noise in a 20Hz...20kHz bandwidth.
4.5V / 2.6uV = 1,730,000
20*log10(1,730,000) = 124dB
What about this Benchmark doesn't clear the lenient limits and come close to the strict ones? It has been measured here, and they have AP measures in the owners manual.That's fine, I personally have no issue with someone postulating that amps passing the "strict" criteria are indistinguishable by any human observer. It sounds eminently reasonable. But I don't think it applies to much, if anything.
Then you get into this grey area, that's also fine, but I don't think anyone can act as if someone swore in the ASR church if there's some claim of hearing differences in the grey area. Not saying there are myself, in this particular example that started the thread - just to be clear. But you have plenty of members who went directly for snark and insults, as always the case, which unfortunately has been building a particular reputation for this website.
Most amplifiers on the market don't seem to have this level of detail available at all, so there's nothing to be said. I've been looking at the usual stuff I find at dealer auditions - Bryston, Accuphase, Rotel (Michi), Krell, Naim - it's usually the case they fail even some of the "lenient" criteria listed above.
Sometimes technical reviews are strange. Looking at the Lyngdorf TDAI-3400, I found two articles right here. The first shows it's a basket-case of bad measurements. The second finds it's rather good because of its EQ and therefore is recommended...
I didn't say it doesn't. But we made tremendous progress from "all amps sound the same" to "look, there's Benchmark and this $13000 Mola Mola".What about this Benchmark doesn't clear the lenient limits and come close to the strict ones? It has been measured here, and they have AP measures in the owners manual.
Benchmark AHB2 Power Amplifier
Benchmark's new AHB2 Power Amplifier - "The Quietest, Cleanest Audio Amplifier on the Planet"benchmarkmedia.com
