Jumper Cables vs Stock Jumper Plates
MarkWinston
Maybe this subject has been discussed and beaten to death before but in your experience does it make anything sound better? Scientifically it does indeed make a difference but is it audible? Also, any thoughts on how to connect one single set of speaker wires? Both red and black to the low frequency posts, both red and black to the high frequency posts or maybe one wire to the lf post and the other to the hf post? Does it make a difference? Has anyone made measurements and compared it to one another?
The copper conductors will possibly oxidise but if used tightly there should be a gas tight seal where the binding post clamps down on the copper. I don't think a difference in sound will exist but I prefer the gold plated jumper plates.
No.
Cables indeed do have lower resistance, but regular brass/gold plated straps will transmit any "audible" signal just the same within such short lengths.
Electrical measurements will show differences, but there won't be anything to see in the acoustical domain.
1) We don't know for sure what material blend is in the original connector plates
2) Cross sectional area matters and so does contact area to the terminals where the plates seem to win vs the wire.
3) Only part of the amps energy goes through the plates, the bass woofer uses most of the current.
4) Short distance between terminals.
I am not sure you could measure the difference, even with quite elaborate equipment and then only if the shims are made of sub-par material. Audible - I can't imagine.
Really, how?
Conductivity wise. Also a stranded wire has a better contact patch when screwed down comapared to something solid. There have been many cases where connections were loose and sq went down considerably. And yeah, it also depends on surface area but I can imagine a thick stranded copper wire (10awg and higher) having a better contact patch than a solid piece of gold plated brass (which is what came with my speakers). Conductivity wise, I have had quite some experience with it, as a competitive vaper voltage drop is an issue we always face and a thin strand of OFC as a switch always outperforms a switch made out of brass. So it might probably show on the paper but whether its audible or not Im not sure.
Why though? It has been reported that many people could hear a difference after replacing those stock plates and Im here asking if anyone here have tried it or could hear a difference or have a scientific explaination to it. Conductivity wise its almost certain that a 10awg stranded OFC would perform better than a gold plated brass plate.
Many people hear many things after changing something.
Just have a short thought how this will change the overall resistance of the complete speaker wiring. Than do the math how this influences FR of the speaker. And after this tell me again there is a audible effect.
It won't when good contact is made.
The latter may well be a higher possible issue for the plates and depending on where the cable to the amp is connected to.
Chances are when one changes a plate that makes proper contact by cable you can hear an improvement. In this case it can't be contributed to the plate vs copper cable.
That was THE question. Is there any scientific proof or stats that show a difference. No more no less. And even if I were to ask members here if anyone has noticed an audible difference, it would still be a legit question.
contact resistance due to corrosion or limited current handling due to Xsectional area are the only possible mechanisms that could cause a difference in SQ
if installed for < 1 year then both are nil
I suggest trying automotive jumper cables
Audiophilia! Bah, humbug. Why piss so many nervous little puddles over something so insignificant? Any sound difference would be belief, not eardrum driven.
Just tried it myself with 8awg OFC stranded wires. I dont have jack to measure a thing but I can tell you for sure those stock bridges that came with Diamond 12.2 are junk. In this case it worked out great, mids and top end gained resolution which is audible even to my wife's wet ears. Those still in doubt can go try it themselves, untrained ears could easily spot the differences. Would definitely work on inferior plates, caused by either fit or material.
There is only one way to really improve SQ: remove the bridge and go active.:cool:
