Blumlein 88
- Joined
- Feb 23, 2016
- Messages
- 23,571
- Likes
- 44,574
Seems like a good method to you I'm sure. But it isn't. Do some measurements or you'll continue in a circle of confusion just guessing about what is going on.Okay, here's what I did:
1. First of all, I noticed what JustJones said above when I went to change the DPLL setting to zero. It actually says on the Loxjie D30 menu that lowering the value lowers jitter. So, I guess, what I have been doing is raising the jitter (or the setting that is supposed to address it) rather than lowering it (unless Loxjie implemented this feature backwards!)
2. Next, I listened to about 5 minutes each of the first and second movements of Beethoven's 9th symphony on my Denon 600NE CD player: first with the DPLL setting on the D30 at zero (minimum or no jitter), then with the DPLL setting on Maximum. There was less distortion on both than with the Wi-fi signal streaming from Amazon music -- but, that said, the Maximum setting was better. Setting it to zero made it sound a bit muddy -- not to the point of distortion (which is what the streaming signal sounded like to me) -- but I enough to make me prefer to listen to it at Maximum. It sounded a bit smoother, too (if I can use that word without setting off an argument).
3. Then, I listened to the same selections, using the built-in DAC on the CD player. It was very hard to distinguish between the output of the D30 with the DPLL value at Maximum from the Denon DAC when I flipped between them. I couldn't say whether I liked one better than the other. IMHO the Denon DAC does well with recordings like this (symphonic, where all the instruments are in one big studio or hall and tend to blend together) and less well with contemporary music or jazz combos with fewer instruments, recorded track by track, with potentially a lot of separation between them.
Which brings me back to a post that I made earlier, to the effect that a wider variety of music should be used to evaluate DACs and other audiophile equipment. Specifically, I feel that classical and contemporary music scored for symphonic instruments is under-represented (perhaps because they are harder to record or render?) I mean, really, distortion and noise are often used intentionally in a lot of genres and it seems to me that some tracks would sound just as good regardless of the hardware and settings used to reproduce it.
Doing more uncontrolled sighted listening longer with more music will get you nowhere
