MaxwellsEq
- Joined
- Aug 18, 2020
- Messages
- 3,597
- Likes
- 6,383
When I started working in recording studios, transformers of this nature were used a lot. Some very expensive mixing consoles had one per channel built in. There would also be a cupboard with several standalone transformers. USB was years away from being invented.What a piece of snake oil scam!
It only changes the signal in audible and if you look carefully it actually adds distortion!
This obviously is sarcasm but nevertheless I see double standards here.
With cables and power conditioners, other products get instantly labeled as snake oil without a fair test
(they can’t fix a problem that's not there).
Same here, but this somehow gets a pass because it could conceptually work?
If CMRR of any particular AMP or DAC/AMP is never measured, how can we know if this improves CMRR and how much?
And how much would it change with using better cables or maybe a USB "filter" or isolator?
Time is money and engineers can't waste time trying to find what's causing a hum or buzz. Bands being in their preferred keyboards and processors, many of which are single-ended or badly balanced with questionable behaviour. These sorts of transformers were used to make such devices "safe" to plug into the very expensive mixing console.
The conclusion you might want to draw is that a great deal of older (pre 1990s) recorded music you have heard has passed through at least one of these sorts of devices.
