Jensen PI-XX Isolation Transformer Review
Rate this isolation transformer:
    Votes: 3 3.3%
    Votes: 10 11.1%
    Votes: 60 66.7%
    Votes: 17 18.9%
This one mentions using *Jensen transformers. Dyou think it's the same?
Based on the internal photo in post #3 and the one in Radial's user guide they are using a different model of transformer.
Images of Radial TWIN-ISO.
Added bottom image.
Those transformers are different than what is used in the Jensen Iso-max. Rather than inline passive isolation transformers it looks like they are intended for use in active output circuits.
I did dozens measurements of link transformers. Even driving them from close to zero impedance does not help much.
It's not exactly clear whether you mean zero amplifier output impedance or zero effective drive impedance (which requires negative amplifier output impedance)? Only the latter will reduce LF distortion as much as possible but is more prone to chaotic effects when overdriven (nasty foldover with level hysteresis).
To avoid ground loops, isn't a balanced connection enough?
Not necessarily, unfortunately. AES-48 has said how balanced connections should be implemented for many years now, but still some manufacturers don't follow it. This means that there are still products on the market with a 'Pin 1 Problem' - in other words still possibly causing ground loop issues even with a balanced connection. Any manufacturer not following the standard really deserves naming and shaming.
Thank you for the review, @amirm, :)
If such an isolation transformer is to be used for removal of hum (ACPL type), wouldn't the hum itself (possibly) saturate the core?
Wouldn't the reliance on such an isolation transformer, a band-aid fix for a major inter-connectivity issue?
Someone may be interested in the following from Jensen site:
Just a question: how would these trafo's compare to the ones in, let's say: the universally praised input stage of an 80's Neve console? Would they have better, worse, or just other characteristics? Can coupling trafo's for audio ever be what we now consider perfectly transparant, or will there always be a compromise? Just general interest on my part. And a short story to explain...
In the late 90's, when I did my stint at an infamously underfunded and archaic filmschool as a soundengineer, the use of opamps in professional audio gear was generally frowned upon by my "teachers" (air-quotes because, you know, filmschool... :)
Grammy winning records had been digitally recorded, mixed, mastered for more than a decade, but since all we had were some handed down digidesign888 interfaces that functioned as the front end for the AMPEX 2" multitrack, it was easy to ignore that there was a big world where things were changing fast. Digital cinemacameras admittedly were still somewhat in their infancy, and our sound dapartment was to be kneecapped until digital camera's had caught up. We might just not have had ANY money, but one does not speak of such trivial matters among artists.
Magnetic tape, negative film, coupling trafo's and hard liquor (for cleaning and desinfectant purposes only!) had always done the job, and would go on doing so. It should. It was a case of late stage denial and open doubt about all things digital. General consencus before the last round: it would remain a prosumer thing.
I dropped a NAGRA IV in a cold lake four feet deep. Let it dry out overnight, and with some basic tools and tweaks I was good to go again the next day. Even the recording was salvaged. Could you do that with a portaDAT? Nope, knobs still ruled over buttons. Such lessons can be hard to unlearn.
Into the preamp at appropriate position. Or output of the sound source + buffer. Why would you place the pot into the transformer box?? It does not make sense. You will use the transformer in between the signal cables.
The idea was not to multiply boxes, and the 2-channel version of this device looks much like the Nobsound Little Bear MC2 that I have between my DAC and Power Amp (no pre).
I suspect they are broadly similar. Many consoles of the era used Jensen, Sowter or equivalent grade transformers. The mid 80s saw the growth of competent electronic balancing as well.
@amirm - sorry but why no frequency response measurement? Or am I blind and can't find it?
Also different loads would be very interesting, at least 10k and 1-2k (mic input). Maybe as Extreme 600R (AP could do that easy).
And for the people with the open photos (thanks btw) - can you read what values the compensation circuit parts have? (C and R) Would be a good starting point for own implementations of these transformers.
You can just download the spec sheets from Jensen, they have everything, including detailed measurements and recomended circuits with component values.
With transformer you get galvanic isolation.
So you are also protected against hazard.
At home your system should be safe. But in public you can’t t be to sure.
It can also be to protect rest of equipment from catastrophic failure. Normally after tube gear or mics
It can also be used as a fault detection device. If it helps the source or input or the power supply scheme probably need a fix
What a piece of snake oil scam!
It only changes the signal in audible and if you look carefully it actually adds distortion!
This obviously is sarcasm but nevertheless I see double standards here.
With cables and power conditioners, other products get instantly labeled as snake oil without a fair test
(they can’t fix a problem that's not there).
Same here, but this somehow gets a pass because it could conceptually work?
If CMRR of any particular AMP or DAC/AMP is never measured, how can we know if this improves CMRR and how much?
And how much would it change with using better cables or maybe a USB "filter" or isolator?
Not sure how you reach that conclusion. A transformer isolates two devices galvanically with a CMRR of 85 dB which is higher than any other solution. There is a little distortion and phase shift at LF as a trade off but no added noise. This is a device that does exactly what it says it does and does it well.
And where is the data to back up this claim? (well compared to what)
why not for example isolate the digital signal on the USB side.
reviews for devices that do this don't test the CMRR and are not as favorable
Discrete electronic solution are ~60dB CMRR depending on matching of resistors. Some chipset solutions are ~80 dB CMRR. Amir measured 85 dB CMRR for this device. In addition to high CMRR transformers give full "galvanic isolation" which can not be done with electronic solutions. If you have a "bad" ground loop the Iso-Max will solve it without adding any noise and just a little distortion. It also requires no power, does not get warm, and will last forever. The only "problem" with transformer solutions (besides a little distortion) is cost. High quality transformers that don't add much distortion or cause roll off in the audio frequencies are expensive to make and always will be.
While these transformer based solutions are not for everyone or every situation Jensen does a good job with them, has great customer service, and provides great documentation. They really are one of the "good" companies in the industry and very far from "snake oil".
The Jitterbug is not a transformer and doesn't seem to do much and is not intended for ground loops as far as I can tell.
So where is the data and the test for this?
"Would it not be be better if the Equipment would not need this. "
"With porperly dseinged equitment you would not need this"
This or something similar is the argument Argument given with USB filters and other devices.
Why sell something to improve CMRR but never test CMRR without the sounds improve device... sounds like snake oil... :)
Why would you need galvanic isolation. you only need high impedance at noisy frequency...
and there are many true USB isoaltors, DACs with build in Isolation and high impedance Analog to digital ground. and other solutions like Toslink...
But all this is not Quantified and tested nor is the CMRR of any AMP.
"doesn't seem to do much" is not very scientific.
i'm sure they are...
