filo97s
Hope that amir can clear the mystery!Great question. I downloaded the manual, which says the following, only increasing the mystique:
2nd Harmonic Steps
Default: 0, with a range of -75 to 75
3rd Harmonic Comp
Default: -20, with a range of -75 to 75
Incidentally, it also has a DPLL Bandwidth setting which sounds like the same thing the SMSL SU-6 has. If so (is it?), lower is better; set it to the lowest value that works properly (no glitching or dropouts) with your equipment. The manual says:
DPLL BANDWIDTH
Default: 7, with a range of 0 to 15. This setting directly impacts jitter rejection, with the optimal
value dependent on timing stability of your PC or audio source. Most audio sources produce
stable audio when DPLL is set to 5. We have conservatively increased the default DPLL value to
7 in order to support a wider range of sources, especially modern 4k TVs. If you encounter
stuttering, try increasing DPLL Bandwidth.
Don't know which chip is using for D/A conversion, but maybe is something related to the ESS thd hump compensation.
