JDS Atom Amp+ Review (Headphone Amplifier)
jams3223
"Power current protection"
What's that? If you are thinking fuses, no it won't work. It needs DC protection that detects DC component from the headphone output. DC protection was implemented since the beginning but due to some threshold, component issue it wasn't working.
Certainly the issue was blown out of proportion. Yet full recall was issued. The actual number of burnt headphones we hear is very small. And people who contacted us got compensation for it.
"they keep on changing the component since topping is a experimental Chinese company that works based on customers review"
?? Totally not true. And don't know where did you get it from.
Bruh topping is a Chinese company operating in Shanghai
THW
I have a feeling John takes issue with the other things you said about the company, not that it is Chinese.
also i’m quite sure its based in Guangzhou, not Shanghai.
jams3223
My advice is to stay away from replying to those biased person who's clearly trying to provoke you.
That’s dark why would I hate the guys I feel the most comfortable talking with over the internet I don’t wanna have a ‘I am the one who’s right fight’ just wanna give my point of view from my analysis ain’t try to offend anybody or to pick a fight just hope we can learn from each other
jams3223
I am fairly sure Shanghai is waaay too expansive for a small start up like topping.
Topping doesn’t have to be a big company who knows it might be run by a couple folks as a startup no company is big unless there’s some big investors
jams3223
Gongzhu seems to be the city but I taught i saw bathe manufacturing facility being in Shanghai and the company office at gongzhu but anyway I don’t know why he mad about what I say also I don’t favor any company just what they have to offer
Diable
I saw misunderstanding and misinformation, I correct it.
If you want to correct something, why not publish legit 2v output ratings for the L30? You guys have been selling the L30 with those jacked up unattainable +3v power numbers for years now and that really needs to be corrected.
THW
tbh i wouldn’t say 3V is unattainable, i can effectively get those results by connecting L30 to my NX4 DSD’s headphone out on high gain
ReaderZ
Which is completely pointless as NX4's performance is shit compare to SToA desktop Amp.
THW
ok, so take another great desktop amp and connect L30 to its headphone out if you really want that extra power (you really don’t, 2V into L30 can already go really loud?).
ReaderZ
So you chain 2 L30 for significantly less power, more noise and almost the same price as A30 pro? Not really a good idea.
THW
I mean I don’t think anyone really needs the full 800 mW @ 300 ohms of power, and I think chasing maximum power that you will never really use is pointless and dumb, so…
confucius_zero
Just received my amp+ and compared it against my old amp of 2018 using a switcher.
Physically nearly unchanged, volume knob definitely more fluid/smooth to the turn and inline with the better build amps like monoprice liquid spark.
I'd say subjectively at similar listening levels that the amp+ seems to sound "faster and wider" with better dynamics (attack-decays) amongst other technical sound improvements like deeper bass and a less shouty midrange. I'm using IEMs of various sensitivities and heard no technical defects. It's the improvement I was looking for, thankfully arriving before I had to consider to spend more on the Topping A50s and above (I really liked the A50s but this amp sounds close to it while staying SE).
Hopefully someone can compare these amps using science machines so that we can perhaps better measure the difference that would cause all these improvements? I've started to see people on other sites measure SINADs at other data points than just 1khz... perhaps we can see differences there?
(forgive the picture showing 2 knobs at various clock positions, it doesn't represent the tested settings).
John's claim of great sinad performance across the sweep.
JohnYang1997
China
I think this is post initiated by SBAF.
Here's my response to people.
https://www.audiosciencereview.com/...-headphone-amplifier-review.15226/post-836706
https://www.audiosciencereview.com/...-headphone-amplifier-review.15226/post-836276
TLDR: low output impedance(good amount of feedback) and load independence will basically guarantee good performance with real headphones load at various frequencies.
Atom is certainly fine. Atom+ upgraded the opamp for better performance. It's also certainly fine.
confucius_zero
Cool so I'm looking forward to see those tests done on the atoms :)
ricochet
Does the Atom+ make sense in combination with a Focusrite Scarlett 8i6 audio interface and Sennheiser HD 650 headphones?
I produce, mix and master my own music.
Diable
Yes, it's loud but it's not the 3w's Topping is advertising. When paired with the E30 dac the L30 will output about as much power as the Atom but less than the Heresy.
D
Deleted member 26571
Guest
You must be slow cause overlooking a companies lies is retarded. I have no clue how you think it's dumb to demand a product actually deliver what's it's advertised as having. People paid for this amp thinking it produced x amount of power when it doesn't. Future buyers should be made aware of this so they can avoid buying Toppings products.
You are mistaken.
