I mean that you shouldn't have any problem with your headphone with the RAW-MDA1. You can of course add the Atom if you want.... but I believe it has less output than the unit you already have.
Why would he want to sell what he has to buy something else with lower specs?
I don't think I will return it cause I think the dac sounds great, it has dual ES9039Q2M. The features are great too. It has XLR and RCA connections. I will double check the settings tonight for the Gain. But I believe I set it to high already. PC also put the volume to max. I really don't know what else to do. Like I said from the previous post, most of the songs are playing just fine with my HD650 headphone. Just some songs (not many), I need to adjust the level to the max "0" in order to hear it little loud. May be just that album recording.
Be lets say if I want to improve the sound quality and better Volume Control. Will this JDS Labs Atom Amp a good choice ? I believe the HD650 has little high impedance.
