JCALLY JM20 MAX Headphone Dongle Review
Rate this portable DAC & HP Amp:
    Votes: 7 3.2%
    Votes: 1 0.5%
    Votes: 24 10.8%
    Votes: 190 85.6%
I just got the KZ PRX and im pleasantly surprised how fun and alive they sound, but coming from the Pure's with Jcally JM12 (flashed with the Fiio firmware) they need more power. I got quite found of the PEQ option, so will the JM20 Pro will be enough to drive Planar IEMs, so i can have and eat my cake at the same time?
JM20 Pro will most likely be more than enough for the PRX, unless you apply very high negative preamp with PEQ. Anyway you could think about TRN Black Pearl, not much more expensive than JM20 Pro. It has balanced option if you ever need more power, same PEQ function (walkplay) and new firmware that addressed the DRE issue.
Balanced connection will need a 4.4 mm cable, so another little investment like this.
Aside not being recommendable due to being susceptible to Cirrus Logic's distortion hump issue (only the Pro variant), I think JM20 Pro runs with the impedance sensing of CS43131 on. That mean it could be limited to just 0.5Vrms into 15Ohm KZ PRX, which might be even less than your current JM12 is outputting.
Below is link to the post with graph showing Impedance vs Voltage of regular JM20 made by StaticV3
https://www.audiosciencereview.com/...20-headphone-dongle-review.58749/post-2214533
Thanks for the answers guys, ordered TANCHJIM Stargate II from SHENZHENAUDIO, the price was good and they deliver faster than AliExpress. Hopefully it can drive fully the PRX. The set is amazing can't comprehend how something for 25$ can sound so beautiful.
If I remember right, my vanilla JM20 checks the load impedance only when turning on, so if you connect it with a low ohm load already attached, it will switch to low gain, but if you connect it wit nothing attachaed it will set to high gain 2 Vrms and will not change it when you plug in the headphones.
With my Ugreen HiFi Pro you have to use an adapter to trick it, since it won't turn on wit nothing plugged and always turns off when you unplug the headphone jack.
Hi All, I have been reading a lot of forums regarding the jm20 MAX and it brought me to buy one. I've connected this dongle to my pc running Windows 11. The sound seems to fade in every so often (1x or 2x a minute). Anyone else having the same issue or know a fix?
Tested with my S25 Ultra, all works well.
I’m new here and to headphones. I’ve been using the HD560S on PC for two months and I tried it with a friend’s DX1. I really loved the details and everything, and clearly prefer it to the Apple dongle. Should I get the DX1 or JM20 Max? It doesn’t have a 6.3 mm input like the Apple dongle after all.
The DX1 is technically better than the JM20 Max (see "Part II: Another Testing Method" and "Additional Remarks after Part II Tests" of my review). However, in reality, I bet you won't hear a difference, especially given that unlike other CS43131-based devices, the JM20 Max's DRE distortion occurs very rarely.
Sorry if wrong place, just need to ask. I bought DX1 yesterday, used it all day. Detail is amazing but over time it started feeling like sterile, zero warmth and “feel.” Does it need EQ to fix it? Apple dongle gives fuller bass extension and more emotional vocals. Is it DX1’s sound character or just clean technical nature? Would JM20 Max sound different?
I wish I had both “feel” and great detail. Any advice would help me.
Zero warmth and "feel" compared to what setup? Compared to when the HD560S was connected directly to your PC? Or Apple dongle?
Compared to Apple dongle on PC. On the other hand, Apple dongle is far from DX1 in detail.
DX1 is transparent, what's more it runs on an AKM chip and people who believe in chips having sound will all tell you AKM has warm, smooth and full sound, while Cirrus Logic (Apple dongle) usually is cold and crisp :P
Anyway, the first assumption should be that Apple one is wrong (but we have it measured and we know it is decent aside one issue), whether some kind of low end distortion, something related to Cirrus Logic hump (the mentioned issue), or simply underpowering the headphones. However I've ran into an issue with Apple dongle where it would change the sound depending on USB host, although in my case it was boosting treble and sounding thin (so more like high frequency distortion...). While desktop DACs theoretically should be more resilient against influence over USB, I do recall seeing someone mention he picked up interference on DX1 while another USB powered DAC was fine. So if there is any issue with host affecting the DACs it could affect both Apple and DX1. The simple way to check that would be to use a different PC or even a mobile phone, although Android has its own ways of affecting sound so you should only compare both DACs on the same platform (also try an app with exclusive USB mode like free HiBy Music or paid UAPP, you need to set it in settings and close the app with exit button to restart first though).
But honestly, the answer you will find the most is probably - the difference is in power. Followed by question "Have you level matched the loudness/volume on both?". Not matching the listening levels exactly is the number 1 issue causing differences in perceived sound where there shouldn't be any. Moreover, to my annoyance I haven't tried HD560S yet, but with most Sennheisers of this construction they kind of like being ran loud, the top end and details come up to the point when listening on lower levels might even feel muffled for some in comparison. This almost exactly matches description of your observations. US Apple has 1Vrms on tap, EU/Global Apple has just 0.5Vrms, DX1 has 3.89Vrms, that is a considerable difference, especially since HD560S was measured by DIY Audio Heaven (user solderdude found here) to have 108dB/V sensitivity.
As such I would simply suggest using Equalizer to adjust the sound to your liking. There is simply a good chance that whatever other good desktop DAC you would buy instead, the result will be the same as with DX1. But by all means, if you want to get to the bottom of this, try perfect level matching the signal out of the devices, and different hosts to figure out if there is an inherent difference between the sources or not.
@fws gave a really good, detailed piece of advice. Consider any difference in perceived sound quality between DACs (except for obvious noise or distortion) fabricated in your mind until you can perform a proper, level-matched blind ABX test. The HD 560S is considered having a bright tonal balance, anyway. You may want to EQ it. EQ'ing is a must for nearly all headphones in my experience.
Anyone managed to play native DSD256 files via Raspberry Pi 4b with Ropieee installation (or other Pi OS) without roon resampling? I have no success playing any DSD through the Jcally Jm20 through roon without PCM resampling. In UAPP with my Android phone it works though. I would like to use this as a budget solid RAAT zone with other players supporting RAAT. The CPU of the Pi have some struggeling with the resampeled stream that can cause dropouts. Is it possible to get Ropieee and Jcally jm20 max usb-c dongle to play native DSD256 if i tweak it in some way or change Raspberry OS?
My JM20 MAX just turned up, and it's great - no problem powering my HD660S with essentially Oratory1990's EQ (but with a touch more high frequency and a -9 gain). But I had to switch to using a spare Raspberry Pi 4 (instead of the Raspberry Pi Zero 2 W I've been happily using for my 7Hz x Crinacle Zero:2) because I seem to have stumbled into a problem - or at least something similar - I now see reported all over the internet.
I use exclusively moOde to listen to lossless music and as I adjusted the volume, fiddled with moOde options generally, or just listened as one track ended and another started I noticed that the sound would dip and then fade up over about 0.5 seconds. Repeatably. It made it totally unusable. I could also trigger this problem 100% by connecting via SSH and typing man top although regular top usage itself didn't cause the problem.
Some people reported it being linked to wifi usage on their PCs - turn wifi off and it goes away. Well, that's not a solution for anyone using a headless device only controllable over wifi.
I read about people flashing other devices firmware to get past one problem but I'm not sure this is 100% the same problem and once flashed there's no going back; don't really like the sound of that.
For Lightning devices, an ordinary adapter to USB-C won't do the trick.
You'll get a pop-up message stating that the connected USB accessory draws too much current.
The solution is an adapter with special MFi chip inside which tells the iPad to supply current to the dongle.
An example: https://www.ddhifi.com/en/product/tc28i-m2/
@staticV3:
2 Questions
1. can you tell me if the original Apple Camera Adapter would also do the trick for my trusted iPad 6?
This adapter is not very expensive and I like its flexibility.
2. if so,
if I would grab the original Apple lightning to 2x USB 3 Adapter (here at eBay:
https://www.ebay.de/itm/205405723435? )
Would it be possible to listen to music via the JCally JM20 Max with the USB C Port and charge at the same time via the USB A Port (5 Watt or so)
I ask, because normally it is recommend to charge via USB C, because much more power.
Thank you (Sometimes I wonder how one person can have as much audio knowledge as you)
Yes, I have it and it won't (Apple USB2 CCK). The error message pops up.
The Apple USB3 CCK has USB-A out for your accessories and Lightning in for supplying aditional power and pass-through charging your iPhone/iPad. So it's not USB-C charging and you have to use the USB-A port for your dongle.
Hi, I've just obtained this DAC-Amp and noticed that it gives hum/distortion/noise to the sound when I'm turning off or turning on the screen on my Android phone (Samsung S23). Only during the screen animation is active and maybe 1s after.
Have anyone experienced this issue too?
I remember having very similar issue with some other audio device attached to this phone, but don't remember which one :/
motorola 40 pro / lineageos and no issues of this type, so likely samsung is to blame. can you check voltage between devices?
Thanks.
Probably no, don't have enough USB adapters :/
But i've noticed that this issue happens sometimes, not always. Weird.
I also have Fiio JA11 - didn't notice anything wrong with it...
