These look exactly like the modules produced by TTGK (https://www.szttgk.com/en). I suspect the TTGK modules are integrated and distributed by a bunch of OEMs--look at the "Application" section in their website.CB5100 certainly yields interesting results if you want to build your own dongle or make a custom USB-C DSP cable for headphones. The tinkerer in me has awak.. oh, 40 bucks, nevermind.
This is funny. I think I own some of those products.These look
The same procedure as in:@Hasan Aydin posted a link to an analysis of the potential pops & clicks caused by the Class H mode often used on these CS43131 chips—don’t know about the JM20:
CS43198 and CS43131 DAC sound defects
reference-audio-analyzer.pro
I don’t think it’s a big concern for a dongle used with IEMs or easy-to-drive HPs, but it may be worth knowing.
www.audiosciencereview.com
You can use the earphones, but cannot make calls using the inline microphone.Does this Jcally JM20 work with an inline microphone cable?
No, get the apple dongle for that. Or if you use Android devices or reside in EU skip the Apple dongle for a CX31993 dongle such as JCally JM7.Looks good! Deciding between this or the Apple usb c dongle. Does this Jcally JM20 work with an inline microphone cable?
It begs the question, who is affected by that? Given that most inline mics are fairly sensitive, at least my Gate mic cable had plenty gain to spare. And, mostly used for calls where ambient noise almost always is higher than SNR. If better metrics matter, than output limited to 0.05V instead of 1V must be very bad. At least that's what you get with Apple dongle on some setups: https://www.audiosciencereview.com/...le-usb-c-headphone-adapters.5541/post-2021949FYI, both cx31993 dongles that I own have 20-30dB lower mic gain and some 5-10dB lower mic SNR than the Apple dongle:
Recommendation for a USB Audio-interface DAC/ADC for ADC performance
using USB DAC/ADC/Audio Interface with a Raspberry Pi 4B - as a BirdNET Pi (it detects and automatically identifies birds by their song/calls) I am using a Clippy EM272 Microphone via TRS-TTRS converter...www.audiosciencereview.com
The sensitivity of inline headset mics can be all over the place.It begs the question, who is affected by that?
I've frequented a discord channel for years where CX31993 dongles are recommended regularly. No one complained about the other party not hearing them clearly in calls. On the other hand, numerous complaints about reduced output from Apple dongle when consuming content. You could say it's a discussion of theory versus practice that we are having.The sensitivity of inline headset mics can be all over the place.
If you want to make sure that the person you're calling can understand you all right, getting a dongle with plenty of gain seems like a reasonable approach.
If the difference was just 5-10dB, I wouldn't've mentioned it.
Thanks a lot! I ordered the apple usb c dongleYou can use the earphones, but cannot make calls using the inline microphone.
Near zero issues with the JM20 (or the Max). I have a Samsung Galaxy FE S20 5G. Sometimes if I unplug it by accident or brainfart and immediately reconnect it, it won't work. So after unplugging I need to wait for about 5 seconds before reconnecting will work.Has anyone else been experiencing
connectivity issues with to the JM20? I have to unplug mine and plug it in again to get it to work (this is on a Pixel 8). I'll test it on my laptop later and see what dmesg reveals. -J
Never used with phone, no issue with laptop but not really useful information for you since it stays still on the table.Has anyone else been experiencing
