norman bates
weird...............
The sound is more than flat frequency response and off axis response ?
lol
lol
Of course we are talking about the rooms. A loudspeaker, the room, and the location of the speaker and listener within that room all work together to make a system. Speaker designers jump through difficult and often expensive hoops (large anechoic chambers, taking outdoor measurements, using ground plane techniques, and using the Klippel Nearfield Scanner) to avoid the effects of rooms so that they can design their speakers in a neutral setting.What we are talking about here has nothing to do with rooms.
All you say make sense but... these speakers image so precise even if you put them in the most wrong position and room possible. It would be so cool if someone else had them or could hear them.Of course we are talking about the rooms. A loudspeaker, the room, and the location of the speaker and listener within that room all work together to make a system. Speaker designers jump through difficult and often expensive hoops (large anechoic chambers, taking outdoor measurements, using ground plane techniques, and using the Klippel Nearfield Scanner) to avoid the effects of rooms so that they can design their speakers in a neutral setting.
The 4410 is a very competent speaker, but like all others has strengths and weaknesses. The fact that you have a system where they work well for you is wonderful. Did you discover a hidden gem? I wouldn't go that far... I think it is more likely you found a speaker that scratches your itch. Bravo. I owned the 1400 Arrays for several years... nice and polite, image pretty well, but sound a bit murky in the low end. I moved them to a secondary system because I found speakers I liked more and then I moved them along.
FWIW: Dr. Toole and Harman have done the research and proved that accuracy and neutrality is preferred by most people... but it is not universal. Some people prefer Klipsch, some people, prefer Dr. Hardy's Altec sound (it can be pretty seductive), and some people prefer this or that. You like the sound of the 4410.
Probably quite a few around, they were in production for two decades. Three versions, last manufactured up to 3/3-2006(!).All you say make sense but... these speakers image so precise even if you put them in the most wrong position and room possible. It would be so cool if someone else had them or could hear them.
I'm ready to be educated, please go ahead
Ok, I don't necessarily subscribe to everything JBL marketing says - and didn't read itTo begin with, see, for example, the article at the link provided.
I (currently?) do not have a well-founded and confident opinion on this matter.
. Phase/polarity/timealignment is complex, and at the end of the day maybe not as important as thought in 1985, perhaps. I heard Wolf of Magico say so, but a lot of effort has gone into the subject...Is JBL Marketing the same as Floyd Toole?)) AE article seems free, what subscription are you talking about?JBL marketing
No, I don't think Toole worked in markeding for JBL. By "subscribe" to marketing I mean believing everything being said in marketing materials, specially back in 1985 or so. It was hard to know the truth, no ASR existed. Stereophile was there, but Fremer recommended cable lifters ffs...Is JBL Marketing the same as Floyd Toole?)) AE article seems free, what subscription are you talking about?
OP (and we along with him) wants to find the reason for the amazing sound of the 4410. Will this transparency disappear if he, OP, changes the phase using a FIR equalizer?
Others did research too, Genelec comes to mind. When JBL made 4410, Genelec made 1022a.Dr. Toole and Harman have done the research and proved that accuracy and neutrality is preferred by most people...
Thousands of people have owned them and heard them, and yet mysteriously we have no other reports of magical imaging qualities.All you say make sense but... these speakers image so precise even if you put them in the most wrong position and room possible. It would be so cool if someone else had them or could hear them.
To answer the question you originally asked?Why would I want someone to come to my house and measure my speakers?
Air is transparent. Water is transparent. Loudspeakers are not.Why would they not measure flat? The same room, same position, different speakers I get 30% of transparency.
So, what measurement measures transparency? I am not talking about boosting highs or doing EQ. I could try eq-ing for forever and I would never get the transparency and resolution of the 4410's.
If it was only about FR we could eq them all so that they all sound the same, which absolutelly does not work.
So, which measurement is for transparency?
Loudspeakers are not transparent? We don't strive to have transparent speakers that do not color the sound, that do not hide details that are in the recording?Air is transparent. Water is transparent. Loudspeakers are not.
You sure you're not just trolling us all?
OK, let's say loudspeakers are transparent, what's wrong with that?Loudspeakers are not transparent? We don't strive to have transparent speakers that do not color the sound, that do not hide details that are in the recording?
The truth, as JBL said it in their sales promo. I think they were on to somethng with the spatial detail and the phase characteristic, and the compression (what compression?)
no any noticeable compression for hi-fi within using volume range is normal)).(what compression?)
It would be helpful to have the actual measurements, wouldn't it? We don't know whether your loudspeakers are actually transparent.Loudspeakers are not transparent? We don't strive to have transparent speakers that do not color the sound, that do not hide details that are in the recording?
