JBL SDP-55 Audio/Video Processor Review
Magnus definitely is good at handling wires No doubt …surely changing systems every time could learn better how to do it properly.. but imagine selling a normal customer plug and play instead of massive amount of rca and xlr out of a surround processor or the extra channels from Avr atmos , carrying all the dust and Hum of the room on those ridiculous RCA cinch ( Xlr is much better as no hum for un-expert on grounding ), instead using Dante can become one connector only between processors and external amps then also if speaker wires would use speakon instead of spades or bananas will be cut in 1/4 again for those as they can carry four wires in each connector instead of one . But nobody use …apart pro audio…true that wireless bring delays , but if the surround processor carry onboard cpu cache and ram memory ( today available and cheap ) with advance loading of the media being played , could bring wireless option with active speakers ( unbelievable how cheap is a good Class D amp ) and without audio delays . Plus quite easy to plug electric outlets . Instead of incorporating kilometres of costly speakers wires in the walls … Engineering can be done in different ways and manufacturers one time where very happy can sell turntable, cd, preamp , pre phono ,separate amp , integrated amp , connectors, expensive wires . Now very much less thing to rip off people’s and even less in future
I utterly fail to see how having to have electric outlets near every speaker is logistically "better" than RCA wires. A wire is a wire. It's easy to run RCA cables. It's a bit more work to run a whole bunch of electric outlets and keep them to code and in the walls (you can run RCA through wire molds along the base board or through the ceiling if there's an attic above). Wireless is another ball of wax. It introduces MASSIVE delays into the system (~150ms-250ms) There's nothing like playing a PS5 game and having the audio lag the video by almost a quarter of a second.
Hi Magnus yes a wire is a wire in theory , but some introduce or are prone to noises etcetera , if You talk about RCA for me they aren’t good anywhere’s , as XLR are so much better and can be small size even for long runs .RCA cannot and it’s very prone to EMI . Wireless I mentioned is about the potential to be used with properly designed items . Doesn’t exists yet for movies I guess unless they may do with nas or processor firmware reading software like Audirvāna for 2 channel Audio which I guess store cache of the track for no audio delay . If you off it still sounds with the sound on the memory . Also NAS are having some kind of similar software . I guess . Problem is NO STANDARDs from manufacturers as usual . Look at how good and safe is speakon connection for example but can’t sale expensive wires that way
I meant to say speaker wire. I don't know where RCA came from.... Brain fart. I'm old. XLR is great for long runs (My pro mics use it), but I've got a couple of 25-30 foot speaker wire runs and I no interference here.
