I cant its just too deliciousSell the rum and get better speakers.
I would pay more for some better speakers than jbl 104 but i think i will stay with them due to low depth size.
Just a bunch of psychogustative bullshit.I cant its just too delicious![]()
Where did I say which patent it was? A loudspeaker does not consists of just one part or patent and KEF is working on the coaxial design since 25+ years being now in the 13th generation and has mainly other cost pressure than a 3-way Genelec. Also have you seen the measurements of their latest generation, they are also very smooth and continuous, https://us.kef.com/pub/media/documents/rseries/rseries2018-white-paper.pdfKEF minimized diffraction and licensed it to Genelec? Seems like it should be the other way around... The coaxial driver on the Genelec 8260 is continuous and smooth, unlike the double gap designs KEF has. (One gap around the tweeter, one gap or surround around the woofer.)
I think more than 25 years. I was selling the UniQ speakers like a C55 in the mid 80's. No idea how long before that KEF was offering this sorta stuff.Where did I say which patent it was? A loudspeaker does not consists of just one part or patent and KEF is working on the coaxial design since 25+ years being now in the 13th generation and has mainly other cost pressure than a 3-way Genelec. Also have you seen the measurements of their latest generation, they are also very smooth and continuous, https://us.kef.com/pub/media/documents/rseries/rseries2018-white-paper.pdf
Apple and pea comparsion, an active speaker has much more filtering inside than a passive crossover, trust me, the Genelec coax wouldn't much measure much different with a passive crossover like the KEF does and this isn't something negative as they are both the best engineered coax drivers on the market available.The measurements are good, yes, Genelec is just better in the frequency domain:
KEF Reference 5: (±3dB) 40Hz – 35kHz
KEF R11: (±3dB) 46Hz - 28kHz
Genelec 8260: (±1dB) 29Hz - 21kHz
Which is why it seems like KEF should be asking Genelec to help them design things, rather than Genelec licensing things, because most of KEFs work seems to be on their driver design, then maybe bracing and flexible ports... The Genelec I have doesn't seem to use any of their methods (no flexible port, not internal braces taking up space inside, no air gaps between coaxial driver parts,), and performs better in a smaller form factor.
They are both the best engineered coax drivers on the market available.
Nobody liked my psychogustative coining. The expectation of a certain flavor or quality changes your perceptions. In this case, the glass looks like a dodo, so... it's yummy!Just a bunch of psychogustative bullshit.
I would also welcome an active 3-way KEF very much, but to also tell the truth even their passive Reference 1 doesn't measure considerably worse even on axis (and of course off axis) when compared for example to a Genelec 8351 if we compare measurements done from the same external tester (Prof. Goertz):Sounds like we'll have to wait for KEF to make an active version of their Reference 5 to see what they can do. and how it compared. Or even an R300 with more bass extension, perhaps by throwing another driver on the back like the Buchardt A400 active speaker. Unfortunate that they haven't made an active three way, as I'd like to see more things at or a step up from the LS50W, Elac Navis, Phantom Reactor, and B&W Formation Duo..
Even their passive Reference 1 doesn't measure considerably worse even on axis... compared for example to a Genelec 8351 if we compare measurements done from the same external tester (Prof. Goertz):
View attachment 48040View attachment 48041
View attachment 48042View attachment 48043
Sources: https://www.fidelity-online.de/2016/08/23/kef-reference-1-messungen/ & https://www.soundandrecording.de/equipment/studiomonitor-genelec-8351a-im-test/
Not a fan of nitpicking, but the 8351B should be way better than the A; especially for that astronomical price.I would also welcome an active 3-way KEF very much, but to also tell the truth even their passive Reference 1 doesn't measure considerably worse even on axis (and of course off axis) when compared for example to a Genelec 8351 if we compare measurements done from the same external tester (Prof. Goertz):
Well, you still have their own, which are usually accurate.I also hope so and that it will be also measured by S&R.
The noise floor for jbl 104 is quite high, I would set the volume to around 20 to 30 percent if possible.Hello, users of JBL104. What is your volume level (knob position) when you are listening? 50%?
