JBL HDI-1600 vs 708i?
jdubs
Hey guys, is the 708i worth the price differential?
-Jim
jhaider
It depends. 708i is a much more capable speaker with much better drivers - ring radiator compression driver with wider HF dispersion, bigger midwoofer with all the JBL tech (neo differential drive motor). It is also larger and uglier, and limits pairings with consumer audio systems because you need either the noisy Crown amps or a BSS BLU processor.
J
jdubs
I can handle the dsp via HQPlayer so I don’t need that Crown amp or BSS processor (thank god!).
Chrispy
PNW
Are the 708P amps "noisier" than the Crowns? What is the noise worry in the Crowns particularly?
jhaider
People assume that because someone cracked the BSS macro password and published the results they can use any DSP…I don’t agree.
If you’ve measured the along output from BLU loaded with the macros, (as I have, from BLU-50) and compared it to same settings in standard filters (as I have, using miniDSP 2x4HD and Monoprice HTP-1) you would know that some BSS filters use slightly different math. (2x4HD and HTP-1 were basically the same, the differences coming from the coarser volume steps in HTP-1).
For 708 the difference is admittedly less than 705, but the fact remains that you’re not actually getting the designed voicing by entering the “cracked” specs into a standard processor.
Fan noise is the issue with Crown DCI. Otherwise they’re fine.
J
jdubs
You mean constant Q vs. proportional Q?
Jim Matthews
Taxachusetts
Of you're considering the 708i at retail, the powered version is only slightly more expensive and is a successful implementation of DSP and internal amplification.
I don't mix with mine, they're for dedicated 2 channel playback.
I couldn't be happier.
crappypanther
For me 708i are much more interesting. 70x is senior series of JBL studio monitors. The only one problem is black color only
a|F
I have a pair of 708P and 705P for sale if interested in trying them out. ;)
J
jdubs
No. I mean some of the BSS math seems to be a proprietary variation of RBJ.
This seems extremely unlikely. What would be their incentive to do such a thing?
Also, can you illustrate an example of these “math” differences?
jhaider
I’m only reporting what I’ve measured. No idea (or speculation, or care) regarding motivation.
I could, but I won’t. I have shared my data with someone I trusted wouldn’t use it to further attempt to pirate IP.
Trust me or not, I don’t particularly care. I’ve done the measurements and you have not.
