JBL goes Dirac Live ready and Class-D
I wonder why Harman wouldn't utilise a brand like HK or Arcam for boxes of electronics? I find it interesting how they'll use the JBL brand for everything from $30 bluetooth speakers to six figure loudspeakers
Every young person I know has a JBL Bluetooth speaker. They’re dominating the market here. Best of all, each and everyone I’ve spoken to has been ecstatic with the performance. It makes sense for JBL to harness this happy base to upsell to more expensive audio.
without full pre-out RCA!
They are not really necessary.
MA9100HP spec:
Rated Power @ 4Ω (20Hz – 20kHz, 2 channels driven, 0.5% THD max): 240 W RMS
You won't find such specs with the usual class-AB AVRs. Even with an A1H, nothing is guaranteed for 4ohms, except a short term output power ;)
Btw. a low EPDR is not a problem for class-D.
This is potentially very interesting to me. My home theater system is in my living room, so aesthetics and form factor matter, and I'd prefer to have a single box than separates for both reasons and for simplicity. I only have 5.1 and would max out with the addition of maybe height speakers and a second sub just in terms of WAF. (someone please design discrete upfiring atmos bar that I can put on or behind the top of my TV instead of set on top of my front speakers!)
I want a single box that measures well, has strong output power for at least 5 channels, Dirac, supports the latest standards, and preferably is as small and nice looking as possible. There are some "slimline" avr's out there, but typically have much lower power, and nobody has seen fit to do a slimline pre/pro that I could stack on a box with 5 nice channels of class d amplification. My long-term complaint with AIO receivers that shows up here again is that to get more power you generally have to get more channels, which I don't need.
I'll be interested to see how well they measure and how much power they really have at comparable levels of distortion to other tested AVR's.
At least from the videos, it seems to look better in person.
IMO, a "fresh-looking" take on the AVR, and prices look competitive, though added cost of Dirac Live license (349 USD for "Room Correction Full Bandwidth") and measurement microphone (Dayton Audio UMM-6(?) @ 79.98), and if you don't already own one, a compatible MacOS or Windows PC, need to be considered.
Size, weight (<8 kg!): Look just about perfect for my purposes.
Bluetooth output for use with wireless headphones is a welcome offering, hopefully no latency issues. Alternately, I wonder if the Zone line outputs could be used in combination with headphone amplifier for wired headphone users. Tried something similar with Marantz, but the line-outs on my model didn't support HDMI sources.
Harman Kardon brand doesn't seem to be getting a lot of love these days, wonder if it's becoming more OEM-oriented (automotive), or simply being phased out.
Quality looks fine.
Not having a bunch of pre-outs I'm never going to use is a feature, as far as I'm concerned. These aren't intended to be giant boxes with a back panel full of rarely used connections. Except for the phono input, but realistically there's probably a lot more people hooking up vinyl players to their AVRs than there are people hooking up external amps.
Still need to see the measurements to see how well these were engineered, of course.
It's like an Onkyo NR7100, but with decent power.... (i am making assumptions)
I believe the Dayton Audio IMM-6C is recommended for the built-in setup/room EQ, which is $40. I haven't seen anything recommended for Dirac Live asides from the UMIK-1, though, which is $110. But yeah, buying into Dirac Live is never cheap. I am curious to see how much the built-in room EQ can do on its own. It does specify (in the manual) that it focuses on the low-end response that's dominated by room interaction, which is the correct way to go about it.
Also, given that the science seems to suggest that you really shouldn't use room correction above 500Hz or so, right where Dirac Live Limited Bandwidth cuts off, is it really worth the extra $100 for the Full Bandwidth version?
These remind me of the Harman Kardon AVR1510, 1610, 1710, 2700, and 3700 which were their last receivers they produced around 2013. The backs of these AVRs are almost identical. Harman used AB amps with switching power supplies in these. I remember discussing them in an AVS group back then. I wonder if JVC built theirs using a similar platform. The three smaller receivers as well as the two larger ones are very similar in size as the HK. I look forward to hearing them, and hope we will get a report soon from new owners.
With DL, correct measurements without time shifts are important. Therefore, for a more complex RC it should be at least a UMIK-2, see also here: Link
I hadn't really realized it until I saw the most recent YT video posted to this thread, but JBL/Harman/Samsung has apparently bought into the big (hypertrophied) chunky knobs school of design. :facepalm:
I blame Kinki.
I read the manual, this has no web browsing feature for advance configuration and also, no app for control of the AVR's, just the streaming service!? Anyone else found anything else or?
Looks good with all class d. I wonder what the reviews/measurements will like, have to say not expecting too much from it th, other than being a well built avr.
Not surprising from this no frills "boutique" product!
Class D amps in an AVR is so non-existent that you are paying a premium for the novelty of it all!
Is this really a problem? If it was, why would Dirac recommend the UMIK-1?
I blame Kinki.
They're pretty standard chunky knobs by AVR standards.
Is this a big thing? I quickly looked at the manual for an Onkyo and the web interface was only for configuring network options, not any kind of "advanced" settings. Do other brands have extensive web/app control of their AVRs?
Only Dirac will be able to answer these questions.
Fyi - @Flak
That is, sadly, true -- now that you mention it. :(
That said, this marantz, e.g., isn't as jarring to me as the JBL -- the whole box is so huge, the knobs don't overwhelm it. ;)
I guess I am just disheartened after JBL did such a nice job of evoking their classic SA-600 integrated amp in the (fairly) recent SA-550 that I had higher hopes. ;)
Well, not sure, it depends on what the GUI can show. Regardin the app, yes, they have at least, controlling of their AVR, which the MA's doesnt have, if I understand the apps on the app market.
The observations made by Dirac, is that at the level at which RoomEQ works, and for the faults which it is designed to remedy, the Umik1 is more than ample.
