JBL Endurance Run 2 Wired IEM Review
Rate this IEM:
    Votes: 3 2.2%
    Votes: 15 11.0%
    Votes: 76 55.9%
    Votes: 42 30.9%
Exactly which Xero 2 (Zero 2?) are those? I see several with similar names on Amazon and ebay.
I type too quickly for my brain and should pause to check first if the spell-check doesn't pick it up - apologies.
It's these as tested here -
Twenty quid currently (I paid twenty five). I also have the previous 7Hz Zero and when herself is watching telly and bearing in mind my hearing issues now, the slight 'toppier' balance suits well and there's still plenty of *clean* bass available.
I had them and returned them the next day. The stetoscopic effect of the cable was too distracting for me. I have other wired earbuds and this cable was by far the worst. I could hear any slight brush against my skin/clothes. Too bad it's true that for the price they sounded good.
Bought a pair and got them yesterday-off of Amazon.. So far, I dig them. They have a flare behind the ear bud that does a very good job of sealing the ear canal. Which in turn amplifies the sound of ones breathing, a good seal. That is also a bit of a minus, as these JBL's make it harder to hear what is going on around me, which I don't like... Bass sounds great to my ears and they have a very spacious sound. No Eq at the moment. I like them quite a bit better than the Zero 2's that I bought some time ago, plus they can do phone calls as well. Of course, it has only been a half a day with them so far...
Amazing at this low price, and a "Household Name" brand, besides.
I've never found an IEM that I can wear. They ALL hurt my ears, even the custom ones. Alas.
in Aus price difference maybe due to wireless vs wired, I saw the BT ones then checked as apples aren't apples
View attachment 408059View attachment 408060
OK That makes sense,Occam's Razor, I will still maintain my sceptical paranoia of individual dynamic pricing algorithms.
@boswell thanks for the clarification I missed it.
Just got mine.
First impressions running through test tracks using iPhone (Spotify) > Lightning cable DAC-AMP > JBL ER2 without eq is of good sound and comfort right out of the box with medium tips.
And the packaging is also well done.
$10 delivered, wow. And it looks like you can get a trial of Amazon music as well right now.
I'll be skipping these as I have a collection of IEMs already fulfilling my purposes. I don't need waterproofing, and I believe it come with acoustic tuning tradeoffs to design an IEM around that requirement.
However, I can appreciate that though has been giving to fit security, this is an issue I've had with multiple inexpensive IEMs I've tried.
Got a pair off Amazon for roughly $10 had a listen and ordered a second pair. Not bad! Comfortable and do a good job on the ear seal.
Rob :)
This is a review, listening tests, detailed measurements and EQ of JBL Endurance Run 2 Wired "sports" waterproof IEM. It is on kind loan from a member and is on sale for $9.95 on Amazon including Prime shipping (retail: $19.95).
As you see, there are magnets at the end of each formed earphone to lower the amount of tangling. I found them comfortable to wear. There are over 15,000 reviews on Amazon (4.5 stars) which means many people feel the same way. Let's see if they are right performance wise.
JBL Endurance Run 2 IEM Measurements
After a few minutes of adjusting, the two channels locked in together with excellent seal, generating the following frequency response:
The general shape is similar to our target. Seeing how our target is approximate, could it be that this curve is fine too? Listening tests will have to answer this question. Until then, here is the deviation from our target:
Deviations are ±3 dB which should be audible.
Distortion is low enough at 94 dBSPL but I am not happy with the rise at higher SPLs:
Impedance is low.
Notice the slight variation in the same area that we had distortion.
Combined with average sensitivity, driving the Run 2 should not be hard:
Group delay is uneventful as is the case with most IEMs:
JBL Endurance Run 2 Wired IEM Listening Tests
After putting the largest tips on to get proper seal, the instant impression was "this is warm" but followed almost immediately with impression of "wooly" sound. Not much mind you, but it was clear that there was a bit too much of good thing in bass department, even for this bass lover. So out came the EQ tool:
Let me say that on a couple of clips, I preferred the No-EQ sound due to nature of the bass in those clips. But otherwise, the equalization tightened the bass, increased spatial qualities (due to low treble boost) and interestingly enough, slightly less harsh sound. My only guess for the latter is reduction of harmonic distortion. Note that these are mild enough that you could easily live without them for less important content.
Without EQ, my sub-bass tracks felt like someone had put a pump in each ear and was pushing air inside of my skull! The sensation was quite uncanny. With EQ, that got reduced a bit but impressive bass was still there. Detail, again with EQ, was excellent and overall enjoyment at top level.
When I was at Microsoft, we would have routine reviews in front of Bill Gates. One of the common events was that he would yell at us for not using this and that technology from Microsoft Research who had done a recent demo of something for him. Just because Harman has researched listening preference doesn't guarantee that product groups attempt to productize. In the case of Run 2 IEM, we have an example of divisional alignment resulting in an ultra-low cost IEM which makes a good attempt at complying with Harman research target. They are 90% there, opting for more bass to likely compete with others who go overboard there. Fortunately it is a slight exaggeration that you can correct with a bit of EQ. Once there, you have an excellent IEM for the cost of a single sandwich at a fast food restaurant! What's more, the thing is waterproof to boot!
I am going to recommend the JBL Endurance Run 2 Wired IEM. Fine tune it a bit more and it would get my highest praise.
I see that there is a wireless (BlueTooth) version of these for a similar price. Is the audio performance likely to be the same?
It's an issue i had with all my cable down style iems until i learned that rolling up the cables making them passing over and benath your ears (just like cable up iems) makes a great difference, mimimizing the stetoscopic effect to a great extent. Probably the early contatct of the cable with the ear skin acts like "discharging" the most of the effect and also stabilezes the cable movements. Ok, if the cable is microphonic on its own it will remain so but much much better.
Thanks for the suggestion. I have since purchased the Moondrop Quarks for 10$ less. The cable doesn't do that as much and they sound as good if not better. I have tried them over the ear or "regular". I didn't noticed a difference. Then last week I purchased the 7Hz x Crinacle Zero:2 but with a "good" cable ie Tripowin Zonie 16 Core. Of course it's silent. And the stock cable of my QKZ x HBB is never as noisy as the JBL one.
I think the JBL cable is partly hollow.
That's really a shame--especially since these are named Endurance "Run" 2. Doesn't sound like something you'd be able to run with.
Thanks Amir!
For those interested here is how Amir's results compare to Sean Olive's. (Dr. Olive was kind enough to share with me his results when I was working on a general IEC711 to GRAS 45CA-10 conversion filter to use with my own measurements.)
Pretty darn good! This shows good manufacturing consistency, especially when considering that the high frequency resonances aren't aligned (the ones around 8kHz), which always means some shifting around between 3-10kHz. Neither is "better" as our ear canals are all different but it is easier to compare results when this resonance is aligned. (I rely on it to better understand channel balance for instance.)
Images curtesy of Sean Olive's twitter account.
From what I have read that strong bass boost is how JBL likes it for their "sports" headphones, and I imagine the thinking is that it works best at the gym or outdoors.
Regardless, Dr. Olive's EQ recommendation on that twitter thread allowed many of us to hear the 2019v2 Harman curve as intended from Harman itself for the first time given the price and the fact that he graciously posted his EQ filters in public. Good to see confirmation of the results and additional data here. Gotta love synergy.
Hi, where do I find the EQ used? Twitter confuses me …
How much voltage does these JBLs tolerate? I am running 26mV rms to my Grado SR125 and the are dead silent and sound OK. Quite surprising considering the poor measurements of my experimental headphone system
I want to try the JBLs with my absolutely horrible measuring Chromecast Audio+converted tube amp...
Chromecast analog and Goocle Treble settings
Tube amp noise, output to headphones
Tube amp FR
I look in that app autoeq.app and don't see jbl endurance 1 or 2 . I'm sure I'm doing something wrong. Maybe someone can shine a little light for me.
Hard to say. Some do active correction. Or may have power input limitations. Or be an entirely different design.
