JBL Endurance Run 2 Wired IEM Review
Rate this IEM:
    Votes: 3 2.2%
    Votes: 15 11.0%
    Votes: 76 55.9%
    Votes: 42 30.9%
This is a review, listening tests, detailed measurements and EQ of JBL Endurance Run 2 Wired "sports" waterproof IEM. It is on kind loan from a member and is on sale for $9.95 on Amazon including Prime shipping (retail: $19.95).
As you see, there are magnets at the end of each formed earphone to lower the amount of tangling. I found them comfortable to wear. There are over 15,000 reviews on Amazon (4.5 stars) which means many people feel the same way. Let's see if they are right performance wise.
JBL Endurance Run 2 IEM Measurements
After a few minutes of adjusting, the two channels locked in together with excellent seal, generating the following frequency response:
JBL Endurance Run 2 Sports Waterproof IEM In-ear Monitor Frequency Response Measurement.png
The general shape is similar to our target. Seeing how our target is approximate, could it be that this curve is fine too? Listening tests will have to answer this question. Until then, here is the deviation from our target:
JBL Endurance Run 2 Sports Waterproof IEM In-ear Monitor relative target Frequency Response Me...png
Deviations are ±3 dB which should be audible.
Distortion is low enough at 94 dBSPL but I am not happy with the rise at higher SPLs:
JBL Endurance Run 2 Sports Waterproof IEM In-ear Monitor Relative THD Percentage Response Meas...png
JBL Endurance Run 2 Sports Waterproof IEM In-ear Monitor THD Response Measurement.png
Impedance is low.
JBL Endurance Run 2 Sports Waterproof IEM In-ear Monitor Impedance Measurement.png
Notice the slight variation in the same area that we had distortion.
Combined with average sensitivity, driving the Run 2 should not be hard:
Group delay is uneventful as is the case with most IEMs:
JBL Endurance Run 2 Sports Waterproof IEM In-ear Monitor Group Delay Measurement.png
JBL Endurance Run 2 Wired IEM Listening Tests
After putting the largest tips on to get proper seal, the instant impression was "this is warm" but followed almost immediately with impression of "wooly" sound. Not much mind you, but it was clear that there was a bit too much of good thing in bass department, even for this bass lover. So out came the EQ tool:
Let me say that on a couple of clips, I preferred the No-EQ sound due to nature of the bass in those clips. But otherwise, the equalization tightened the bass, increased spatial qualities (due to low treble boost) and interestingly enough, slightly less harsh sound. My only guess for the latter is reduction of harmonic distortion. Note that these are mild enough that you could easily live without them for less important content.
Without EQ, my sub-bass tracks felt like someone had put a pump in each ear and was pushing air inside of my skull! The sensation was quite uncanny. With EQ, that got reduced a bit but impressive bass was still there. Detail, again with EQ, was excellent and overall enjoyment at top level.
When I was at Microsoft, we would have routine reviews in front of Bill Gates. One of the common events was that he would yell at us for not using this and that technology from Microsoft Research who had done a recent demo of something for him. Just because Harman has researched listening preference doesn't guarantee that product groups attempt to productize. In the case of Run 2 IEM, we have an example of divisional alignment resulting in an ultra-low cost IEM which makes a good attempt at complying with Harman research target. They are 90% there, opting for more bass to likely compete with others who go overboard there. Fortunately it is a slight exaggeration that you can correct with a bit of EQ. Once there, you have an excellent IEM for the cost of a single sandwich at a fast food restaurant! What's more, the thing is waterproof to boot!
I am going to recommend the JBL Endurance Run 2 Wired IEM. Fine tune it a bit more and it would get my highest praise.
Thank you so much for this review!!!
What would be the easiest way to introduce eq when using these with an iphone?
Is there an app that might be able to introduce these PEQ settings into Apple Music or Spotify?
I have these; I got them for use in the gym. There is only one negative: the smallest tips are still too large for my ear canal, so they don't stay in. I called JBL and they said that there are no smaller tips. Other than that [not-too-small] problem, I have no complaints. Performance for cost is great!
Interesting. I broke my cheap earbuds on my last flight back from London and need replacements. Ordered for $10.16 from Amazon. Thanks ASR!
Hallo Folks.
I wonder how do they compare to Linsoul 7Hz Crinnacle Zero:2 in matters of resolution, dynamics and spatiality (but also build quality and ergonomics). Is being watterproof enough to sway active people who look for a good sound?
Is this a case of western audio company playing in the same league with some asian offerings, or is it “trying to catch up, but not really becase they still offer subpar products while throwing money on corporate hodgepodge, instead on how products acutally sound”?
Cheers.:)
I have both, the Zero:2 are my daily driver and they are beyond fantastic!
Here are some thoughts about the EQ.
Please report your findings, positive or negative!
Notes about the EQ design:
  • The average L/R is used to calculate the score.
  • The resolution is 12 points per octave interpolated from the raw data (provided by @amirm)
  • A Genetic Algorithm is used to optimize the EQ.
  • The EQ Score is designed to MAXIMIZE the Score WHILE fitting the Harman target curve (and other constrains) with a fixed complexity.
    This will avoid weird results if one only optimizes for the Score, start your journey here or there.
    There is a presentation by S. Olive here.
    It will probably flatten the Error regression doing so, the tonal balance should be therefore more neutral.
  • The EQs are starting point and may require tuning (certainly at LF and maybe at HF).
  • The range around and above 10kHz is usually not EQed unless smooth enough to do so.
  • I am using PEQ (PK) as from my experience the definition is more consistent across different DSP/platform implementations than shelves.
  • With some HP/amp combo, the boosts and preamp gain (loss of Dynamic range) need to be carefully considered to avoid issues with, amongst other things, too low a Max SPL or damaging your device. You have beed warned.
  • Not all units of the same product are made equal. The EQ is based on the measurements of a single unit. YMMV with regard to the very unit you are trying this EQ on.
  • I sometimes use variations of the Harman curve for some reasons. See rational here and here
  • NOTE: the score then calculated is not comparable to the scores derived from the default Harman target curve if not otherwise noted.
  • Occluding IE devices generally must have very good fitting/seal in the user's ear canal for best performance.
    please spend a few minutes to pick up the best ear tip... Be sure to perform this step otherwise the FR/Score/EQ presented here are just worthless.
  • 1. more bass = better seal
    2. More isolation from the outside world = better fit
    3. Comfort
Good L/R match.
I have generated one EQ, the APO config file is attached.
Score no EQ: 73.0%
Score Amirm: 81.2%
Score with EQ: 96.3%
Thanks Amir!
For those interested here is how Amir's results compare to Sean Olive's. (Dr. Olive was kind enough to share with me his results when I was working on a general IEC711 to GRAS 45CA-10 conversion filter to use with my own measurements.)
Pretty darn good! This shows good manufacturing consistency, especially when considering that the high frequency resonances aren't aligned (the ones around 8kHz), which always means some shifting around between 3-10kHz. Neither is "better" as our ear canals are all different but it is easier to compare results when this resonance is aligned. (I rely on it to better understand channel balance for instance.)
Images curtesy of Sean Olive's twitter account.
From what I have read that strong bass boost is how JBL likes it for their "sports" headphones, and I imagine the thinking is that it works best at the gym or outdoors.
Regardless, Dr. Olive's EQ recommendation on that twitter thread allowed many of us to hear the 2019v2 Harman curve as intended from Harman itself for the first time given the price and the fact that he graciously posted his EQ filters in public. Good to see confirmation of the results and additional data here. Gotta love synergy.
Thank you for the review, Amir! I got two pairs of these about a year ago for my wife and myself. We had never used an iem before and found them to be excellent. I also purchased the Linsoul 7hz Zero's for us and I prefer them but my wife hates the Linsoul and really likes the JBL for the fit. For me the Linsoul with the large tips just fits perfectly, giving a great seal but the body of them seems too big for my wife's ears and she can't get a seal. The JBL's work perfectly for her. She likes that you don't have to push them in too much and they don't fall out easily. I kind of like their magnetic system for holding them together when putting them away :). It really did seem to help keep them from getting tangled when dropped on the desk.
These look to be 20 to 30 in the UK . Let's see what black Friday brings
More to the point it shows measuring consistency in a difficult setup across two different rigs where the tiniest movement can throw out results.
That said, in the case of these cheap earphones, Harman's ridiculous boom-tizz/smiley face curve is reaching new heights with a huge (bigger) hole in the mid-range and (even) more bass. :facepalm:
