- Thread Starter
- #41
The next amp indeed has digital input. Some also have BT so you can stream directly to them.In this connected world of ours, few USB/SPDIF inputs and WiFi/BT, would suffice.
What about JL Audio?FYI this is an airstream interstate RV. So the back is full insulated and finished. There is fair amount of noise in front but it is not remotely like a work van.
Airstream had swapped out the head unit for a Kenwood running Android circa 2016. With a slow processor and clunky UI where you had to log in every time to use the system (!) it has been a pain although its Garmin navigation is a nice back up to Google maps. The sound is mediocre at best, mostly composed of midrange and highs. When driving on freeways, you have to crank it up, resulting in sound that is borderline annoying, although fairly better with new JBL speakers I put in.
My original hope was just to spend a bit of money on DSP and actively drive the fronts and improve things without too much expense. My brother has relocated here who has done car audio install/repairs for decades. So the work of redoing it is not a major factor anymore.
The JBL would have fit the bill if it didn't run so darn hot. Whatever I do needs to be reliable as getting stuck on vacation with no sound would be disaster!
Alas, I have this disease where anything I want to do, eventually becomes a quest for the best thing that can be done.So just ordered another set of speakers (the current ones in the door are just 4 inchers), to go with this expensive Audioson amp&dsp, assuming they perform.
Getting bass is another challenge. That part to come next.![]()
www.idatalinkmaestro.comIf there are electronic devices such as various radar warnings and other functions, it is best to keep the original audio system. Otherwise, those functions will be lost.
I'm currently facing this issue. So I ultimately gave up on modifying the car audio system. But recently, I've been thinking about changing the speakers.www.idatalinkmaestro.com
There are other brands and it all depends on the vehicle and head unit but you can often retain everything in aftermarket.
Some cars now though have pretty good factory systems so upgrading them becomes either a side grade or a massive custom extreme install.
Kevin Garnet was getting a system at a shop I worked at years ago and the shop had to dial the sale way back because the stock system in his car was so good it was nearly impossible to improve.
He ended up just getting some subwoofers installed in a really custom add on, mainly for some extra hip-hop slam. Otherwise there was no room to improve with even top of the line equipment. This was a very luxurious car though. Most any Toyota/Honda/Jeep can be drastically upgraded. It will come at a cost though for real good upgrades.
They have apx515 and also apx555’s to use… the 555 is required for the Brax Dsp, rx2 pro (purifi circuitry) and also the mx4 pro which is the old flagship four channelI don’t know how much size you need, but the Audiotec Fisher line is pretty good and has great software.
Their premium model is in the 90 dB SINAD range and they probably aren’t using an APx555
The budget models:
The other question is stuff like this
Jehnert Plug & Play Speaker System Upgrade Kit for 2019+ Mercedes Sprinter Vans (68601) - Free Shipping!
Upgrade the speaker system in your 2019+ Mercedes-Benz Sprinter with the Jehnert Sound Design Mercedes Sprinter Plug and Play Speaker System Upgrade Kit (68601) from Nomadic Supply Company®. JEHNERT products…nomadicsupply.com
Last, if you have separates, Focal makes ultra small car audio amps
DSP & Amplifiers | Car Audio a la carte solutions | Focal
Discover our à la carte DSP processors and Car Audio amplifiers. To combine the pleasure of driving with the love of sound and music, make sure you have quality hi-fi equipment in your car.www.focal.com
audiosciencereview.com
