How much SPL loss can be expected in such designs with doubling of distance?
I immediately thought the same. I took a healthy-sized rubber band, stretched it, and measured it as I plucked. First, the primary tone was around 250 to 350 Hz. Second, there were a lot of harmonics. Third, I had to pull it extremely tight to get up to 600 Hz, then it broke. A bungee is, of course, much thicker and would resonate even lower, most likely.Maybe they have a resonance of 800Hz
This thing is a shaft of sound coming at you!
Wow! So these speakers somewhat get around the inverse square law (double distance, loose 6dB SPL)?? How??
Thanks for the review amirm!
They are used in commercial applications, do they get EQ?
Yes, these are part of JBL Professional products.
They have special software for deployment...
Another onVery interesting review. Size factor suggests they could be used as R and L for home theater. What would you use for center speaker?
Opinions please. Thanks
Seems that they'd be excellent LCR speakers as well, but I think you'd need an acoustically transparent screen. It's pretty clear you'd get poor results with the speaker on its side.
Anyone have clever ideas for a matching center channel?
