You've been known to abuse your toys.That said they were broken out the box , buzzing noise out of one of my two speakers and later one died. Just distorted one day out if the blue.
That's just PIR, the whole CEA-2034 sheet needs to be adjusted as well.I know. But this is a new file which cntains 240points vs 200 you require, so please take a
I know. Can you please try to import this Estimated room response. It contains 240 points. If it works I can generate CEA-2034 file with same 240 points.
They are quite similar to M16. I do prefer them to Genelec because the 705 did not fall apart with clipping as the Genelec did.
YesSure, I can do it, I was waiting for you to confirm that those 240 points are ok, so are they?![]()
Silly question: doesn't the 705p have built in DSP? So why didn't they correct for the dip?
It's a phase cancellation between the woofer and the port, you can't fix it with DSPI agree with @stunta on this - if that dip is a systematic issue why didn't they correct it? User configurable DSP should be for left for room EQ and personal tone controls and not to rectify systematic issues.
Anyone know how Sound & Recording gets their review samples? Do they buy them or companies provide them?
With PEQ filters you can't , but with FIR?
If you plug the port up with foam, does that dip go away?? 'Not saying that's a solution......just wondering.The dip is happening in the acoustic domain, unfortunately. In theory it could be corrected at a single point in space but practically speaking it is baked into the speaker. Can't be fixed with EQ any more than edge diffraction can be.
One of my b stock 708p had a resonance. They replaced it with a new one that works well. I read about several b stock 705p buyers who had issues and couldn't get warranty coverage, just a return for a refund. So I bought 3 705p and I'll return 1 whether broken or not. Or maybe sell it if they all work.I wonder if the B-stock isn't actually a better bet for reliability.... as I presume they are the ones that already had a problem which was fixed? At the very least they probably got an extra round of QC that the new stock didn't.![]()
Yeah, it willIf you plug the port up with foam, does that dip go away?? 'Not saying that's a solution......just wondering.
Dave.
Yeah, it will
I thougth only room related issues could be corrected at a single point in space while on-axis, LW, ER and SP can be fixed but both DI will remain the same.
Funny thing is it exists only in SP DI but not in Early reflections DI.
EQ could fix it at a single point in space in an anechoic chamber.
So they traded efficency for dip? Maybe dip is not really an audible issue..
