JBL 550p external amplification modification
Depoxy
The plate amplifiers on both my JBL sub 550p subwoofers died, so I am converting them to external amplification with a speakon. I will be powering them using an nc502mp fed by a Minidsp SHD.
The 5110g drivers have a capacitor across the terminals, I’m assuming to function as a low pass filter. Does it make sense to remove the capacitor given that a filter could just be implemented in the dsp, or don’t bother?
I’m still learning about active speaker implementation and I am unsure if the capacitor will cause any issues with the amplifier, so I am curious to hear your thoughts on this. It seems most DIY subwoofers don’t have capacitors on the drivers.
Do you have an idea about the value? This is indeed unusual. It might be something the amp needs to remain stable?
I would assume you don’t need this with a different amp. In fact, class d amps don’t generally like driving capacitive loads.
I don’t have the value, but I’ll remove it from the second sub and take a look at the value before gluing on the new back panel. I'll have to pull the driver from the first subwoofer as I already glued the back panel on. I'm not sure why it would be there as it had a class D plate amplifier to begin with, maybe a cheap way of taming a peak near the top of it's range that would probably be handled by a dsp amplifier if it were built now.
Whatever its original purpose, it is more likely to cause problems than do anything useful with an external amp. Self-oscillating class D amps like the NCORE series don't tend to like heavy capacitive loads.
Thanks guys, I appreciate the feedback. I'll pull the drivers, remove the capacitors, and check for any other hidden resistors or inductors.
Well just in case someone comes across this in the future, I took the drivers out to investigate and it was just a 110uF 100V capacitor across the terminals. I removed them based on the feedback here regarding class D amplification.
