28.57% better.
JL Audio subs?
Room looks like it was "treated" for speakers with a very different radiation pattern. Is there some method to the madness how what ended up where?
AJ,
I am a work-in-progress. I feel like I'm learning how to apply new acoustic concepts in a better way everyday.
A big step forward for me has been learning how to setup subs in a way to almost totally remove axial length modes. It was a real effort to learn how to do it. But I am proficient now. I plan to do a write up on this later using Acourate and REW. Since that time, I became curious about decay times. I've learned more about DIN 18041 decay time recommendations. Decay times should always be referenced to room volume.
So I started removing bass traps and measuring to see whether I could increase my decay to meet the DIN spec, since I was clearly below that for music listening. I ended up removed 4 MSR Spring traps (helmholtz resonators), 2 large GIK pressure traps and 2 large RPG arc panels. I remeasured and found that these traps had zero effect on room mode ringing with my sub setup. Since they clearly eat up decay times and offer no other acoustic benefit, I removed them.
My room decay times referenced to my room volume is now slightly more than DIN standard decay times for music listening. And there's no negative consequences to IACC values. Without any DSP, the total IACC is better than 80%, which is very good for any system.
The room is more lively. The soundstage is more spacious and everything is more articulate.
Michael.
