You made the comment I was just about to post.This speaker is essentially an example of top-shelf engineering using bottom-shelf components.
(Which I find very impressive, FWIW.)
Not necessarily. For trained listeners in a controlled environment and using handpicked listening material, most probably.This says it all I think. Distortion higher than 1 % in the midrange is clearly audible. [...]
If you are an American citizen, please go and vote. I did yesterday./QUOTE]
Uh, Amirm...given the actual post date, you mighty want to change that. Just sayin’
wouldn't be surprised if the distorsion was caused by clipping of the 56W amplifier driving a 8" woofer.
okayyyyy, so for EQ purposes is it wrong to use that curve, which data do we use for EQ purposes? Although surely all the dB values are relative, so it doesn't really matter what absolute value they are, for EQ purposes we just need to know the deviation, so it doesn't need to be "normalised". Basically, what I'm getting at is which data would I need to use for EQ purposes given I want to EQ the listening window? At the moment I've EQ'd based on the listening window data in the CEA2034 file as you can see here: https://www.audiosciencereview.com/...-mkii-studio-monitor-review.17338/post-561866The SPL is incorrect for active speakers. Meaning it is not being measured at 105dB (also, I read through the 2034 instructions and it wasn’t clear what SPL to use, even if the Klipple accurately read it).
The only difference would be compression. Amir doesn’t do compression testing, so we have no way of knowing how the bass will response at higher levels. But yeah, EQ should not be done differently, unless I’m missing something.okayyyyy, so for EQ purposes is it wrong to use that curve, which data do we use for EQ purposes? Although surely all the dB values are relative, so it doesn't really matter what absolute value they are, for EQ purposes we just need to know the deviation, so it doesn't need to be "normalised". Basically, what I'm getting at is which data would I need to use for EQ purposes given I want to EQ the listening window. At the moment I've EQ'd based on the listening window data in the CEA2034 file as you can see here: https://www.audiosciencereview.com/...-mkii-studio-monitor-review.17338/post-561866
It sounds correct to me, and I saw someone else in this thread EQ'ing based on that 110dB level, so I'm thinking it's still valid?
High build quality, high sound quality, low price - pick 2 of 3.Every speaker I have either owned or heard, seems to have one or two shortcomings. If it is not related to cheap drivers or construction, it then becomes, they are overly large, or mostly overly priced.
Not sure there is a perfect speaker in all ways. Something always has to give.![]()
Well, all the data in the attached Spinorama text file that Amir attached is at 110dB, so I'm thinking we can just use that data directly for EQ purposes without any "normalisation".The only difference would be compression. Amir doesn’t do compression testing, so we have no way of knowing how the bass will response at higher levels. But yeah, EQ should not be done differently, unless I’m missing something.
Also, what would likely be the source of distortion between 1-2kHz?
I tested my JBL 305P MKII in a 43dB room, measured on my iPhone using C-weighting.
Only power cord was plugged in.
I put my ear against the tweeter, and reached around the back to toggle the input sensitivity back/forth.
Result? No change in hiss level.
What does decrease the hiss, as Amir also noted in this review, is when I turn down the volume control (the gain) on the back of the speaker down from 100%. This will decrease, but won't eliminate the hiss.
Given the below:
- input sensitivity set to -10dBV (0.3V RMS) - max. input level should not exceed 6dBV (2V RMS)
- input sensitivity set to +4dBU (1.23V RMS) - max. input level should not exceed 20.3dBU (8V RMS)
I was wondering what would be the input voltage were you started to hear that these speakers distort, please? Basically, most balanced sources are delivering 4V RMS, so I guess the +4dBU gain setting should be used, right? Thank you!
I'm also quoting Stump909's post too here, because hiss seems to be eliminated if choosing one of the two gains, probably the +4dBU one.
I suppose it was less popular due to physical size.Glad to see the performance of the Mkii like this considering the original 308p was relatively unpopular compared to its smaller siblings. Can't wait to see the 306p mkii! Do you guys think the speaker can be modded to change the amplification units? Also, what would likely be the source of distortion between 1-2kHz?
but more because they're so big it almost felt like the sound wasn't coming together properly this close
Adam once made a floor stander (Tensor Beta), don't know the price (probably high). It's no longer available.What puzzles me about these manufacturers of cheap high-quality monitors is why they do not make a prettier 3-way floorstander version of them and go to annihilate the hi-fi market at 1200 bucks a pair. Maybe jbl would cannibalize sister brands, while genelec or adam wouldn't.
Anyone knows why?
