Not even near the performance of a Genelec 8030c. But for the money with som modifications, the Jbl 308 mkII is not bad.Sorry for my bad, it seems it’s playing at the level of accuracy as the 8030s at half the price ?
No, but there are a couple of videos with teardowns that shows it has dsp filtering.I don't see any info about that anyhwere.
JBL's website for 705P and 708P mentions DSP crossover, but not 305P/308P MKII
The treble data is more precise now also IIRCWhat new dashboard?
Getting an updated 86/96dB distortion of them would be appreciated though.
The Jbl 308 mkII is a budget monitor, maybe one of the best sounding for the money. But everything inside the loudspeaker is on a tight budget.I once started a thread about Measuring the electronics inside active monitors.
An active speaker is but an all-in-one system and its performance is bound by the rule of the weakest link.
It is of course difficult to perform such measurements, and apparently some believe that because speakers produce more distortion everything upstream is inaudible anyway. Strange times. Or at least strange people.
Its cheaper and better
JBL knows what they are doing. I got the Kalis fearing rear port of JBL might be an issue for my set-up.
Oooh, I remember the same looking JBL monitor, probably the older version yet, it had a lot of hiss noise. I measured that and found -87db(A), so need to love JBL too much to use it at a 1m distanceThe root cause was awful ST class D chip STA350, really low-end stuff with THD+N 0.5% -3db and noisy. I hope JBL jumped to Ti with the current monitor version.
Even with the 308p you might want a subwoofer.308P's stand-alone or 305P's combined with a subwoofer. Anyone have any opinions/experiences they care to share?
In a last ditch attempt I used brute force to make the speakers better. I crossed the over to my subwoofers.
This is not what I wanted to do here. I wanted great speakers that would be as good as any other at making a broad range of sounds at a consistent volume with clarity. I wanted something to end the chase. Instead we are left with an expensive fix to an inherent problem on a damn good, but not perfect, speaker.
Crossover duty was performed by a minidsp, and the subwoofers were powered by my Behringer iNuke amp. (...)
With the low frequencies taken over by the subwoofers, the JBL's sound sublime.
sorry for stupidity, but for the FR and in room response it lookse remakably similar to the 8030 except the 18k peak where 8030 have a dip??Not even near the performance of a Genelec 8030c. But for the money with som modifications, the Jbl 308 mkII is not bad.
This is a teardown of the 305 and 305mkII. Its essentially the same as for 308.I agree DSP crossover is cheaper and can be better but still questioning if this 308P features A-to-D inside.
Still looking around the web for confirmation but can't find anything.
Different story with 708P of course.
I have this speaker and I wouldn't want it sitting on my desk whilst I work on my computer, because of the hiss when no music playing on them. I have them at about 2m listening distance for TV/movie/music use and the hiss is a complete non-issue at that distance (can't hear it), but I wouldn't want them on my desk.So, If I understand well, this JBL is not to use as near monitor because there is a lot of hiss
But also not as far monitor because the power is limited .
Very few use cases where this monitor is adapted for , no ?
Yes, true, and they dig deeper.sorry for stupidity, but for the FR and in room response it lookse remakably similar to the 8030 except the 18k peak where 8030 have a dip??
The sound is much better with Genelec 8030C.Yes, true, and they dig deeper.
The real difference is the distortion.
IC!! being lazy and bad memory on graphs I didn't check the distortion and only look at the FR! it looks like good manufacturers manage to make good studio monitors relative cheap with very good FR like the Adam T and this, but for perfection with distortion then price just goes up like the genelec?Yes, true, and they dig deeper.
I think its mostly depending on :
1. Lack of damping material inside the loudspeaker. The box is almost empty, making standing waves inside the loudspeaker to appear: - distortion. It should be about 3 or 4 times more of the damping material.
2. Lack of crossbracing inside the loudspeaker. The walls are vibrating like crazy: - distortion. Cured with a cross bracing L - to R wall.
Also agree with that - while they are good performers in the bass region, once I added a subwoofer they leveled up.Even with the 308p you might want a subwoofer.
See the review of the LSR 308 written by @NoAudiophile :
http://noaudiophile.com/JBL_LSR308/
