There are better options for nearfield IN-5 shines more at midfield (medium sized rooms)Frankly I would love to go with the In-5 for a near field approach
IN-5 will not show it's full potential at nearfield (smaller rooms)
Is that for the 308 specifically? would you still recommend the same distances for the 305/306?
I know the JBLs are the least expensive good option with Kali coming in at the next higher price point. Frankly I would love to go with the In-5 for a near field approach, but if I'm also buying a good Midi Controller like the Arturia Keylab 61, that's another 550-600US... I'd love to say 200-400 here or there doesn't matter, but the controller seems a more important starting investment than the Speakers.If I had it all my way, I'd have the space and funds to consider In-8 as my starting set. *shrugs
Appreciate any further thoughts or advice!
The measurements show nothing wrong with the woofer...
All the data here : https://www.erinsaudiocorner.com/loudspeakers/kali_lp-6v2/
That's a pity since at ASR we rely on proven facts and measurements.I have data that the review does not, individual driver measurements which I might share, but I also don't care that much about this.
I would think all of the 30Xp Mk2 series would have the same level of hiss, but I only have experience with the 308p Mk2 as those are my speakers. Regarding recommended listening distance perhaps the smaller 305 & 306 integrate the sound better at shorter listening distances than the 308 but I'm just theorising. It does seem like In-5 is ok re those close listening distances from the official specs:Is that for the 308 specifically? would you still recommend the same distances for the 305/306?
www.audiosciencereview.com
The recommendation from someone else on here to buy second hand sounds like a good idea on the surface. Maybe you could buy one of In-X range 2nd hand to fit in your budget. I don't have experience buying speakers 2nd hand but my 308p speakers are coming up to 6yrs old and I think they're just as good as when new.
Dunno if I want that hassle.Everything I've described in my criticisms is already in the data in erins review. Not my problem is people can't read the data.
They will not measure but sound what you get is completely different for different speakers that's how you make a choice.
There is no correlation between what you wrote about the woofer and the data from Erin reviews, that's why I react.
If so you have your own data proving the point, I don't see why not sharing it...
| Perspective | Evidence | Argument |
| "There are resonances" | Nearfield Port Scan | If you put a microphone right inside the port, you see a sharp peak at ~1kHz. It is objectively there. |
| "There are no resonances" | Estimated In-Room Response | In the "Spinorama" (the total sound of the speaker), that 1kHz peak is almost invisible because the woofer's direct output masks it. |
Can't seem to find it, probably deleted it. I measure A LOT of things and tend to delete it after awhile.
I mean everything I said is still in erins review, guess you're just not seeing it, oh well. Lead a horse to water and all that.
In the objective data for the Kali LP-6 v2, there are indeed port resonances, but they are exceptionally well-controlled compared to the original V1 and most speakers in its price bracket."
Yeah so let us know what woofer problem you see on the CEA2034 or the near-field response...
There is no big resonance and my glasses are fine.
I dunno that looks weird to me at first glance. The port seems to be contributing significantly to the response up to nearly 2kHz, and at ~650Hz and ~1.2kHz the output from the port is about the same or even higher than the output from the woofer. I could be wrong but I don't think that's normal for a well-designed port. Normally the output from the port should be highly suppressed that far away from its tuning frequency, right?The measurements show nothing wrong with the woofer...
Maybe, although others seem to have done a better job with a front port. Such as Focal:Possibly due to it being on the front, most of the front ported monitors have similar looking port responses where it trails along with the woofer response. I imagine it's quite difficult to separate the port response entirely from the woofer if the port is on the front.
Granted, definitely a more expensive speaker. But it can be done.
Oh, finally some data showing the problem.It's not well controlled at all, good job AI. I'm really glad that you chose to harm the environment by asking it, and it still gave you incorrect output. Like people stop using AI....
LP6 port is kind of a mess. It has two main resonances and they're not far down from the drivers output. Only about 6-8db. If we look at the audio first fidelia, it's resonance is ~20db down. It'd consider that well controlled.
I set you to ignore actually, have a good one. It doesn't appear you're arguing in good faith. See ya!
Please note your graph isn't similar to Erin's one, at 600 Hz for example, wondering where it comes from.
