- Joined
- Mar 16, 2020
- Messages
- 120
- Likes
- 78
Woohoo!!I have the LP6 to still test.....
Help me to understand why I hear so much of this with many powered speakers? I can stick my ear completely into the waveguide of my 3600s and not hear a bit of hiss from my 25 yo Adcoms. Why can't they design these cheap plate amps to be quiet?And oh, yes, there is hiss from the tweeter. It is very audible with your ear at the tweeter level but is gone at about 2/3 of a meter/2 feet or so.
It’s a function over form design. I’m sure that shape isn’t accidental.All they need to do is get some designer to make their speakers less ugly. This bu**hole look seems to be popular with their designs![]()
These are $20 amps driving a tweeter directly without a lossy crossover in between. Efficiency is higher so noise becomes worse.Help me to understand why I hear so much of this with many powered speakers? I can stick my ear completely into the waveguide of my 3600s and not hear a bit of hiss from my 25 yo Adcoms. Why can't they design these cheap plate amps to be quiet?
Why not building the product to a higher standard.?Monitors that have no hiss up close seems reasonable.These are $20 amps driving a tweeter directly without a lossy crossover in between. Efficiency is higher so noise becomes worse.
I tested my JBL 305P MKII in a 43dB room, measured on my iPhone using C-weighting.Did you change the input sensitivity? That basically eliminate the hiss for me.
You can copy/paste the score if you want.Reserved for scoring.
Sure, I get that. But it should also be a concern when design a speaker. Maybe less so for a monitor, but they have the same offputting design on the 5XX series as well. No one likes an eyesore.It’s a function over form design. I’m sure that shape isn’t accidental.
JBL 308P MKI was a bit harsh to my taste in my room. Sold it
Moral of my story, I should have listened to my ears. When I first got this speaker, I thought it sounded amazing. I compared it to my Revels and JTRs in my main room and thought it sounded as good as those speakers did. I took it into my office and thought it sounded wonderful in there, too. I even tested all the treble settings and found that I preferred the default(+0) treble setting. Then...I measured the response in my office, and it was tilted upwards(not downwards like I expected). After that, I started thinking it was too bright, so I flipped the -2 treble switch on the back, but the placebo was too much, and I ended up relegating them to storage. In some sense I'm happy, as it led me to the Genelec 8030c for my office, but my initial impression was correct, these are great speakers
Second moral of my story, don't trust in room measurements.
