what I run from the Atom to the JBL's:
https://benchmarkmedia.com/collecti...dapter-cable-pin-3-floating?variant=547761981
Are you using balanced cables? You shouldn't have a hum, but only a slight hiss from the tweeter.
What is the consensus on these for a L/C/R home theater application? I'm thinking of 308s for L/R and maybe a 305 or 306 for the center channel. Looks like finding a decent AVR is also a problem....
Agree it'd be a welcome review. But not because I have a pair (I have the 305p) nor because it would tell about the 306 (how?).I'd like to see the 308's tested here on this website by Amir. He's done the 305, so I think it makes sense to test the opposite end of the extreme of the series, that way we could probably assume the 306 was ok if the 308 was ok.....I'm thinking it might be hard to marry the 8" woofer of the 308 with the 1" tweeter. I've got the 308's by the way and run HF Trim at -2dB which also pleases the UMIK measurements for a Harman Curve.
Well I think by reviewing the 308 (now that we also have the 305 reviewed) then if the 308 were to measure well then the chances increase that the 306 would measure well too. My reason for saying this is that I see the 308 as probably the most difficult to get right considering they're trying to combine an 8" woofer with a 1" tweeter....I think it gets progressively harder to produce a good result in a 2 way speaker when combining an ever increasingly large woofer with a tweeter, due to crossover issues. It's also possible that the larger cabinet size can mean increased likelihood of unwanted vibrations & distortions. Therefore I think if Amir was to test the 308 and it measures well (like the 305 did), then it's probably pretty safe to assume that the 306 will be ok too. So I think if you were gonna have to choose 2 speakers to review from the 3 series range you'd choose the smallest & the largest - the 305 and the 308. That's my thinking.Agree it'd be a welcome review. But not because I have a pair (I have the 305p) nor because it would tell about the 306 (how?).
I somehow agree but if you had the 306 you'd probably rather have the 306 reviewed right? ;-)Well I think by reviewing the 308 (now that we also have the 305 reviewed) then if the 308 were to measure well then the chances increase that the 306 would measure well too. My reason for saying this is that I see the 308 as probably the most difficult to get right considering they're trying to combine an 8" woofer with a 1" tweeter....I think it gets progressively harder to produce a good result in a 2 way speaker when combining an ever increasingly large woofer with a tweeter, due to crossover issues. It's also possible that the larger cabinet size can mean increased likelihood of unwanted vibrations & distortions. Therefore I think if Amir was to test the 308 and it measures well (like the 305 did), then it's probably pretty safe to assume that the 306 will be ok too. So I think if you were gonna have to choose 2 speakers to review from the 3 series range you'd choose the smallest & the largest - the 305 and the 308. That's my thinking.
Yeah! But my logic for the greater good is sound! :-DI somehow agree but if you had the 306 you'd probably rather have the 306 reviewed right? ;-)
