Hi,
I am thinking about getting a pair of JBL 305P MkII speakers, but it is likely that I shall be using them in a more typical Hi-Fi listening setup, and not in a nearfield setup. Listening distance is expected to be around 8-9 feet (2.4-2.75 meters), with around 1 feet (~ 30 cm) space from the back of the speakers to the wall behind them. I can place the speakers 6-8 feet apart (1.8 - 2.4 meters), and planning to use stands for that.
I have 2 questions:
1. For cables, my understanding is that each unit has a balanced XLR input and a mono 6.35 mm TRS input. My DAC (Khadas Toneboard) done not have balanced outputs, and hence thinking of using either RCA to XLR cables, or use my existing RCA cables with a RCA to 6.35 mm TRS converter. Which one would be a better choice?
2. For stand height any suggestions? Or should I just try to place the speakers at the height at which the tweeters are at the level of my ears?
I have 2 questions:
