Valentin R
- Joined
- Aug 30, 2017
- Messages
- 201
- Likes
- 309
To bad it’s kid of difficult to send it from Mexico
Amir did not post the data files; I just asked.@MZKM Have you calculated the preference rating for JBL 305p Mkii yet, by any chance?
I'd like to compare to latest Neumann KH80 review.
JBL 305P MKII Preference Rating
SCORE: 4.36
SCORE ignoring LFX: 6.43
They are very similar except for Smoothness of the Predicted In-Room; however, when looking at the smoothness graphs, they are both very smooth; the only way I can think of as to why it has a score thats ~1/2 as good for Smoothness is the tonal balance, the target slope wants a slope-down, whereas the JBL is almost flat. Now, Amir listened to these on a desk I believe, so that is likely the reason he preferred the wider soundstage; the preference rating is for a listening room. Or, my formula is borked somehow that I can't see (but my formulation matches the one that's generated via the graph).
https://docs.google.com/spreadsheets/d/1MDuE6hFfo9pofi2063s6IXqYcxtXMph8gqLLkL9X8pA/edit?usp=sharing
KH80 Radar:
305P MKII Radar
KH80 Smoothness:
305P MKII Smoothness
All of this has be thinking though that perhaps there’s another variable in the research that (at least, as un-educated as I am in this particular field) might be significant... notably, listener’s hearing response relative to the speaker’s frequency response. I note that Toole mentioned that all listeners (skilled listeners, non-skilled listeners) seemed to rank speakers with the same trends (albeit different magnitudes and different consistencies) during blind testing. But did the listeners have generally the same hearing frequency response? I’d suspect they likely did not - so maybe it doesn’t matter as well. That actually seems like as surprising result to me though - one that my simplistic intuition wouldn’t expect.
JBL Control 1 Pro's Preference RatingHey @amirm can we get the measurement data for JBL Control 1 Pro?
So @MZKM can calculate the "preference rating" and @pozz can update the database.
I don't see why the measurement for this speaker can't be compared with others.
A review of the 708's would be most welcome, something that has at least a bit of real bass.I also have a pair of 708Ps. I can only be w/o one at a time. PM if you have interest, LMK how much time you would need them, etc..
He has the 705 and 708 so I asked him to send the 705 first.A review of the 708's would be most welcome, something that has at least a bit of real bass.
Well, that's good since the 705 is the one whose port is supposedly botched.He has the 705 and 708 so I asked him to send the 705 first.
I thought that only the 305P mkII had the treble boost, and that the original LSR 305 was more neutral.
Unless there was a legit site performing measurements using professional gear, and knew how to use it, who then measured the two of them within the same control group, I doubt it.
What happened between the two versions of this speaker ?
