This is a review and detailed measurements of the JBL 305P Mark ii powered studio monitor and Control 1 Pro budget passive monitor. I purchased the 305P Pro Mark ii when it first came out and it currently sells for US $147.50 from Amazon including Prime shipping. This is the price for one so you need to double that for stereo setup. The Control 1 Pro came with my
Klippel NFS speaker measurement system. It is only sold through Pro channel and costs US $164
for a pair.
The 305P Mark ii has good heft and feel to it for a budget priced monitor:
Back panel shows the connectivity and configuration:
The Control 1 Pro doesn't feel like junk but not anywhere close to 305P:
Introduction
This being the first measurement of speakers being published using this new measurement system, it will also act as a tutorial on how to read the measurements. What is presented is a small subset of what is captured but it is the most useful one. Going back to early work performed by Dr. Floyd Toole while at Canadian Research Council (NRC) (early 1980s), a collection of measurements are performed around a speaker to better characterize how it might sound in your room. This work has been refined over the years and the latest version is memorialized in standard known as CEA-2034 or CTA-2034. They are for sale publications but if you search enough, you can find online copies.
The standard and research requires that measurements be performed in an anechoic chamber, i.e. a room without any reflections. If you measure in a room, then you impart its signature on the measurements and the data is no longer valid. Anechoic chambers cost from a million dollars and up so outside of realm of all but biggest manufacturers. Fortunately we now have a Klippel NFS system which using an automated system and heavy math can extract anechoic response of a speaker that is measured in a standard room. In my case, that "room" is our three-car garage. The room has large volume and dimensions which helps a bit but still would not be good without the Klippel NFS system.
One great advantage of the Klippel system is that it measures the speaker at close distances and then computes what the measurements would be like at longer distances. CEA-2034 for example requires measurements at 2 (?) meters. That is actually a bit too close to the speaker for large tower speakers (measurements should be performed in "far field"). Not an issue for NFS system since it measures very close (inches from the speaker) and as such, can get very strong signal captured by the microphone. This makes it immune to environment noise which is a great asset as I measure speaker. NFS system generates CEA-2034 compliant curves given their guidelines and requirements so you don't need to understand these differences.
Harman called the measurements that create these results "spinorama" since the microphone was kept constant and the speaker rotated to make individual measurements. The name has stuck so you might as well be familiar with it.
If you want to understand this topic to as much depth as you like, I highly suggest purchasing Dr. Toole's book,
Sound Reproduction: The Acoustics and Psychoacoustics of Loudspeakers and Rooms:
https://www.amazon.com/Sound-Reprod...-Loudspeakers-Engineering-ebook/dp/B074CHY128
CEA-2034 "spinorama" Measurements
The classic set of measurements required for CEA-2034 is 70 as indicated (really 72 but two are duplicates):
The Klippel NFS system doesn't work this way. It scans up close and then models what the far field response looks like. It requires more points if you have a more complex speaker or are operating in a small room. For the results you are about to see, 550 or so points were used. I will be refining these measurements more so this may vary. The scan normally takes an hour but I told the system to make multiple measurements and average them. This lengthened the time to two hours but I don't think it did much useful (lowering noise). Fortunately the whole process is automated after setup so I ate dinner and watched a movie while it was doing its thing.
Here is the overview of the system results:
The red line shows the on-axis (direction of tweeter) if you did not use the Klippel NFS. It shows a bunch of ups and downs that get worse as you go lower in frequency. These are room reflections (shown in dashed blue) which are interfering with the direct sound. Once these are mathematically removed, we are left with the blue solid line which is now free of room variations.
The vertical dashed line delineates a different technique for getting reflections which is to cut off the measurement after certain time. If you do this right, you can capture just the direct sound. Alas, using a short window of time means that you lose low frequency information. So this technique does NOT work for low frequencies and you need another method. Here, we are letting NFS system solve that problem for us.
None of this is important with respect to understanding of the speaker measurements. So stay with me.
Overall and On-axis Response
When measuring speakers, you select a an acoustic center which is typically a line perpendicular to the tweeter. Keep that in mind and now let's look at this series of curves:
