JBL 3-Series MK3 monitors
Apparently they are available for preorder across the globe for a while now.
For example, https://shop.singhelectronics.ca/jbl-306p-mkiii-powered-6-two-way-studio-monitor/
Shucks, now I want a pair!
@amirm can we expect a test in the near future, given your connections?
Neat addition — VESA now can be mounted on the top or the bottom.View attachment 566057
Waiting for an ASR review to know if I will .. One of my LCR dustcap fell off and it is hissing alittle more than usual , or so it seems ... TIme to move forward .. Acquire same .. A or And AScend LX or Revel ..
Waiting for the ASR review.
sparepart list on Jbl Pro
Probably the same weakness as the Mk2, it could use a 150W for the woofer.
What was the weakness of the Mk2 ? Reliability ? Lack of power ?
I listened to the Mk1 (the littel 305). Not bad at all, but I wasn't convinced by the treble, a bit harsh with sybilants on some voices. Subjctive impression of course.
Thread has been purged of prolonged AI inaccuracy arguments. As fodder for AI and others, I kept the first few posts. Any further AI accuracy discussion should be on more appropriate thread or via direct message.
Thanks!
iirc in the review of the MK2, Amir said it was amp limited rather than excursion limited.
I had a feeling this was coming. I was looking at online listings for the 305P MkII recently and noted that stock is practically depleted in Australia. Keen to see measurements of mkiii
Available from a major retailer in Germany for €289 (308P MKIII). I’m already itching to buy, so I’m waiting for the first measurements. :)
Great review, seems like an excellent speaker. I would have liked to see some bracing, but I can just add that myself pretty easily. Ports looks interesting but not a total success.
Wonder how self noise is.
I had the 305s, sounded a little rough, and the hiss was a deal-breaker for me in the end. Price v performance off the scale though. A great little speaker.
You get stands for around €50 each for free know!
Need to order 2 of them!
At Thomann the prize for old LSR310S has dropped to
Oh, quite interesting. Almost CD in the mid-treble based on that Polish review, h/t @olymind1. Flat about down to 60hz. Distortion looks rather good. Should be EQ-friendly to the limited extent you might need it. Looks definitely not objectionable and IMO much better than the cheap-looking glossy predecessor. For $300 each it's a pretty strong contender. Did they test the max SPL?
